Fabia RS TOP Speed
What is your TOP speed on your un-modified FABIA RS and at how many RPM is your TOP speed.
In my GolFabia RS speedometar doesn't work, and today I managed 4100 RPM in 6-th gear. What speed could it be in km/h.
I have 205/40/R17 tires. What tires are serial on FABIA RS??
In my GolFabia RS speedometar doesn't work' date=' and today I managed 4100 RPM in 6-th gear. What speed could it be in km/h.
I have 205/40/R17 tires. What tires are serial on FABIA RS??[/quote']
Hi
Check out this thread for top speeds. Seems that standard Fabias are good for between 129 and 135mph or 206-216Kph.
Do a search for gear ratios. There is a spreadsheet on here somewhere with the gearing for the car on 16 and 17" wheels with both early and late gearbox ratios.
Chris
Well, on my recent 140mph stint, I was only doing about 4000/4100rpm in 6th.... So you're looking around 220+ km/h. :eek:
Hi
Chris
How do I make a calculation out of gear ratios? Do you know the formula?
i did 147 mph on the clock on my 03 plate VRS i have pikey mod 1 and 2 and the modded cupra intake!
I work it out around 53.7 km/h per 1000 rpm on a later gearbox
4100 rpm will be around 220 km/h (136 mph) assuming the rev counter is accurate
Found this page for calculating.
http://www.scirocco.org/gears/
I have Fabia engine and gerbox of Fabia RS dec/2004, so it's new gearbox.
So if the calculator works fine if I had the sixth gear out of old Fabia 0.756 i would go about 232 km/h. With sixts 0.814 I was going 216 km/h at 4100 rpm
Even with the longer gearing I very much doubt it was doing 147 mph. maybe 5-10 mph over the offical speed but not 20 mph higher.
How do you know? You **** yourself at 130 :rofl:
more importantly what are you doing going as fast as you can on public roads with a speedo that doesn't work?!?!?
:nono:
I guestimate.
I tend not to drive like a **** unlike some...
driving fast doesn't mean riving like a ****. i'd rather sit at 140mph on an empty motorway than do 45mph past a school at kicking out time.
:nono:
I was on the empty motorway at 00:15 this morning. I know at what speed I'm driving on public roads. In 4th gear at 1500 RPM I'm going 50 km/h, and in 5th at 1800 RPM I'm going 80 km/h, and in 6th at 2000 I'm going 100 km/h. Thats all important speeds I need to know. Somebody was driving infront of me and we talked on the cell phone so I remembered that speeds.
its going from bad to worse, your soo lucky your not in the uk mate. would get fisted by the coppers for doing what your doing.
So I'm not in the UK :). I wasn't put anyone in danger except me.
With 1000miles on the clock, ive had 135mph out of mine on the flat with 4 people in the car. Was very surprised as i was expecting far less untill engine had reached a 10k service. 06 Fabia vRS, no mods.
