All parts £10 each unless otherwise stated
Few bits and bobs for sale, all used but in good condition unless other wise stated.
x20 extended wheel bolts (40mm thread) £15 posted
x20 standard wheel bolts (26mm thread) £14 posted
Abs pump £15 posted
Fuel cap in black, black magic (has 2 deep scratches) £5 posted
Fuel cooler £15 posted
Nsr light cluster £15 posted
3x pedal covers (rubber bit worn on accelerator pedal) £15 posted
Indicator stalk £9 posted
Rear seatbelts x2 £9 each, posted
Rear door wiring looms x2 £10 each, posted
Bonnet catch / latch and sensor £8.50 posted
Standard dog bone mount £15 posted
Gearbox mount £15 posted
Rear exhaust silencer mounts £5each posted
Servo £16 posted
Brake master cylinder with reservoir £15 posted
Full set of vac pipes £10 posted
Clutch line £10 posted
Coolant pipes £ 10 each, posted
Alarm siren £8 posted
Securing bolt for spare wheel £5 posted
Steering column (no barrel or keys) £20 posted
MAP sensor £8 posted
Tail gate struts x2 £10 posted
Check straps £10 each, posted
Window winders £5 each, posted
Clutch pedal spring £5 posted
Drivers door lock and ignition barrel with keys (no fobs) £15 posted
How much for the locking wheel nuts x4 posted?
Also interested in heated rear window switch and 2x dashboard centre blanks (to the left of the heated window switch)
Hi, I'm sure I no longer have daah blanking caps or locking wheel bolts but will have a look tomorrow. Should have heated rear window switch but will double check tomorrow also.
Mike
