HELP: Is it possible adjust EGR using VCDS on PD170 BMN engine?
Hi:
My car is a Octavia Combi MKII VRS PD170 with the BMN engine code. I want to know if the EGR valve is working correctly and I have a VAG-COM 12.12.0. I replaced weeks ago the OEM EGR gasket with the reduced 9mm gasket. But I´m not sure if the egr is working properly, even if I haven´t the EML light on. So I need help because I´m not an VCDS expert. I read that te EGR of the PD170 is electronically regulated, and I want to know if it´s possible to check and adjust the EGR using the VAG-COM.
Can someone tell if is possible? Or some link to a tutorial to do it? And a reference to the correct values that the EGR need to have in orden to work properly?
Sorry for my english.
Thanks a lot.
  • 8 months later...
Hi. Did you find out how to do this as I need to set mine to minimum.
