Octavia Mk2 FL Curtain And Seat Side Airbags
I have searched a few threads on here that discussed this (there was some confusion when the FL was released). It seems the curtain airbags changed deployment from each pillar a,b,c to the headlining with just a single airbag badge on each a pillar. My car has the badge on each a pillar.
So my car has these markers on the a pillar, plus the airbag tag on each of the seat side bolsters (side airbags) plus the usual marking on the steering wheel / dash for passenger.
However, on a full VCDS scan only 4 airbag sub systems are returned - see below.  I would of thought 6 - IF it actually has curtain airbags..
Does this mean that i) the seat bolster located side airbags are not fitted when curtain air bags are? or ii) The seat bolster and curtain airbags are on the same sub system? or iii) the car doesn't have curtain airbags and the badge on the a pillar is a mistake?
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q8 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2PXDF8
   Coding: 0020792
   Shop #: WSC 73430 790 00083
   VCID: 3D713C05640948D655-8068
   Subsystem 1 - Serial number: 6332MSME5D257139G
   Subsystem 2 - Serial number: 6342MSME5D452932F
   Subsystem 3 - Serial number: 6351HSME270B070F9
   Subsystem 4 - Serial number: 6361HSME27174C214
No fault code found.
Edited by TheClient
I'm thinking someone must know if the curtain airbags are reported as a separate sub system in VCDS when side airbags are fitted?
My FL only shows 2 subsystems, yours shows 4 I expect two of them are the curtain airbags.
I changed my steering wheel and airbag with no changes to the serial numbers so I believe that the drivers and front passenger airbag aren't reported, only the side and curtain airbags (where fitted).
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC26XCCR
   Coding: 0020788
   Shop #: WSC 73430 790 00097
   VCID: 3D71186764430DF6B0B-8068
   Subsystem 1 - Serial number: 6332MSME63154E54D
   Subsystem 2 - Serial number: 6342MSME624625344
Ok, right thanks. Or maybe the subsystem serial is a generated or stored number relates to both the side and front airbag combined, not a serial number of a specific unit itself?  Just checked my mk5 golf scan (now sold), I forgot I had one saved. That was supposed to have curtain airbags and that only shows 4 sub systems as well.......
