2016 Citigo fuses overview ?
Just gotten a slightly used 2016 Citigo Style with most of the extra i wanted. But the fusebox is different to the one in my Danish manual ...
My car is with automatic shifting and does only have one fuse box - not the extra as those with stop'n'go has at the end of the dashboard. But in the manual there is one row of standard sized fuses and two rows of mini fuses but as the picture below soes there are now mixed so i don't trust the overview in my manual.
Does anyone have an overview of the fuses in this new layout
Got a picture of what the manual says? The fuse diagram is pretty confusing (at least in my 2012 model anyway) @Updown789 can certainly vouch for that
The newest owners manual for download is 2015.11_A00_Citigo_OwnersManual.pdf  and that is what i got a print of with the car. It is grey import to Denmark (was originally registered in Praha, CZ - so it might have had the original CZ manual with the correct diagrams)
Hoped that someone had a newer manual
  1.  Air Conditioning, diagnostic connector
  2.  Headlight range control, park assist, electric exterior mirror adjustment
  3.  Automatic transmission, engine control unit, power steering, control lever under the steering wheel, instrument cluster
  4.  Airbag
  5.  Reversing light
  6.  Rear wiper, windscreen washer system
  7.  Main beam headlamp - left side
  8.  Main beam headlamp - right side
  9.  Not assigned
  10.  Electric exterior mirror heater
  11.  Not assigned
  12.  Vehicle lighting
  13.  Vehicle lighting
  14.  Vehicle lighting
  15.  Vehicle with START-STOPsystem: Radio  -  Vehicle without START-STOPsystem: Central Control Unit, heating, automatic transmission, light switch, license plate light
  16.  Vehicle lighting
  17.  Rear window wiper
  18.  Panoramic sunroof
  19.  Central locking system
  20.  Rear window heater
  21.  Reversing light
  22.  Horn
  23.  Voltage transformer
  24.  Headlamp flasher
  25.  Windscreen wipers
  26.  Radio
  27.  Turn signal lights, brake lights
  28.  Selector lever for the automatic transmission
  29.  Fuel pump
  30.  Engine control unit, instrument cluster, central control unit, rain sensor, control lever under the steering wheel, diagnostic connector
  31.  Vehicle lighting
  32.  Central control unit
  33.  Vehicle lighting
  34.  Indoor lighting
  35.  Vehicle lighting
  36.  Vehicle lighting
  37.  ESC
  38.  Key bar
  39.  Lever under the steering wheel, windscreen washer system
  40.  Engine components
  41.  Brake pedal switch, cooling fan
  42.  Engine control unit
  43.  Fuel pump
  44.  Engine components
  45.  Engine components
  46.  12-volt power socket
  47.  Air blower for air conditioning/heating
  48.  Seat heaters
  49.  Electric power windows
  50.  Vehicle lighting
  51.  Electric power windows
When i look at the above diagram and my car i do not have fuse 43 for fuel pump og fuse 21 for reversing light. Since both are working they most be in a different position ... And since the layout of standard and small fuses has also changed i suspect there might be more differences ....
