DRL's on With Dip Beam
Hi I have upgraded My H15 Bulbs on my 2014 Elegance to Mtec Super white which are great On Drl and main beam but really yellow On Sidelights When Dip is on.
Can I change To Led's have tried a couple of different ones but get a error, maybe setting in vcds? Or recommended alternatives that have been tried
Can I change So Drl is on with Dip Beam instead of sidelights.... Is this legal of possible?
Sorry for the newbie questions
Simon
Thanks to this Forum after some digging I had found the answer
https://www.briskoda.net/forums/topic/340652-vcds-adaptation-for-side-light-voltage/
I have implemented this which works but yet to have a proper look whilst driving at night etc
just extend my thanks to everyone for a great site and members
It won't be legal because DRLs at night will dazzle oncoming road users - they are basically a dim main beam. This is why they are switched off when the headlights come on.
Understood
The setting just increases the voltage to make the side lights slightly brighter (& whiter)
And not as bright as the Drl output and the way it looks to me not as bright as my dip beams so should not be any issues
Cheers
Here is my setup
Philips ultinon h8 in fogs, fogs also used as DRL instead of the H15
Philips Diamond vision in H7 for dipped, the H15 sidelight are dimmed to 5 to get rid of the yellowish along with dipped beam.
I think he disabled only the side light function so main beam / DRL still work as normal.
0% brightness setting can cause bulb out error, so probably that's why the 5%?
Edited by aki78
