DAB radio upgrade
no its a direct fit
  • 6 months later...
  • Replies 52
  • Views 17.5k
  • Johnfc2017
    Johnfc2017
    It is really easy to remove the head unit, you need to pop down to Halfords and pick up some parts. You will need a blanking plate conversion kit and the cable adapter along with a cheap DAB radio and
  • Hi There   Got one for sale. Kenwood KDC-BT73 DAB. It's currently working in my Fabia but I'm selling it as I'm getting a Yeti in 2 weeks. Dead easy to fit and I use a windscreen mounted aer
  • Sorry it's sold
On 31/08/2017 at 22:05, JWvrs25 said:
Dont bother with a windscreen aerial they are total ****, i fitted one of these and its brilliant, full dab and fm signal anywhere. the connections were correct out of the box for my Pioneer headunit so would imagine pure would be about the same
https://www.amazon.co.uk/Hama-Roof-Antenna-AM-DAB/dp/B00LFHUWLY/ref=sr_1_1?ie=UTF8&qid=1504213413&sr=8-1&keywords=hama+dab+aerial
does take a bit of fitting though you have to remove the passenger side plastics to run the cable to the head unit. Well worth it imo.
base looks just like oem and aerial is slightly shorter so gives it a more modern look
as for the faceplate, anything off ebay
Bit of a thread revival here but I’ve just bought one of these for my Mk1 fab, where does the red power (I’m assuming that’s what it is!) cable connect to?
The blue wire in the wiring kit is for a powered aerial, so you should use that, which will work only when the radio is on. Alternatively, you could use a tap a fuse from the rear wiper as that only works when the ignition is on. It saves risking a flat battery.
Additionally, if you are thinking of using a dash cam, the rear wiper is the best choice to power one of those.
