Adaptions/Coding for Kodiaq
Zippyijk
I'm looking for info on the adaptions lists for the kodaiq.
Unfortunately long coding help doesn't work for a lot of the modules, does anyone have any info on how I can read them? i.e. is there a method to read with my VCDS.
It seems that either VAG have gotten better at blocking them or else the module are newer and rosstech haven't decoded all of them yet.
Anyway any help would be appreciated and I'm willing to upload/post what I get from it up here.
FYI here's the autoscan for the modules in case anyone is interested...
Wednesday,24,May,2017,18:18:03:29744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: TMBKC7NSXH********   License Plate:
Mileage: 27   Repair Order:
Chassis Type  NS (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 6C 6D
          75 BB BC
VIN: TMBKC7NSXH8023902
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: Malfunction 0010
75-Telematics -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CZEA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 027 DD    HW: 04E 907 309 BJ
   Component: R4 1.4l TFS   H24 3123
   Revision: R6H24---
   Coding: 011D003224241D083000
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_ECM14TFS01104E906027DD 001003
   ROD: EV_ECM14TFS01104E906027CE.rod
   VCID: 69DF8891880DD2095E-803C
   CAN Converter 01:
No fault code found.
Readiness: 0010 0001
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 042 K    HW: 02E 927 770 AS
   Component: DQ250-6F MQB  H54 5004
   Revision: 06454104    Serial number: TFK01703290131
   Coding: 0014
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 214FD0B130BDDA49C6-8074
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 51037000000571
   Coding: 6007929F3422236F4780060062C54906492CC4E2604692713021F078C2024200002E64121A03102F35351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
   ROD: EV_Brake1UDSContiMK100IPB_035_VW37.rod
   VCID: 76E5D3EDC9B30DF1C3-8022
Address 05: Acc/Start Auth. (J518)       Labels: 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0439658378
   Coding: 032C0C0F03
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   ROD: EV_KessyHellaMQBAB_004_VW37.rod
   VCID: 3C7101C5B71F97A1F5-8068
   Sensor Controlled Power Rear Lid:
1 Fault Found:
1077250 - Transport Mode Active
          U1105 00 [008] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 24
                    Reset counter: 43
                    Mileage: 3 km
                    Date: 2017.04.27
                    Time: 08:06:29
Address 08: Auto HVAC (J255)       Labels: None
   Part No SW: 565 907 044 R    HW: 565 907 044 R
   Component: Climatronic   H04 1801
   Revision: 00001K00
   Coding: 16110004000110011005100800101002
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_ACClimaBHBVW37X 006145
   ROD: EV_ACClimaBHBVW37X_004_VW48.rod
   VCID: 2A5D379D4D8B191197-807E
   Fresh Air Blower Front:
   Refrigerant Pressure And Temperature Sender:
   Air quality sensor:
   Subsystem 3 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H30 0119
   Serial number: 60523958
2 Faults Found:
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [008] -  -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 42
                    Mileage: 9 km
                    Date: 2017.05.18
                    Time: 11:34:13
                    Voltage terminal 30: 14.8 V
                    Compressor shut-off requirement: Shut-off of engine control module via CAN (T > 15 sec.)
1048838 - Functional Limitation due to Energy Management
          B10CD 00 [008] -  -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 13
                    Reset counter: 43
                    Mileage: 3 km
                    Date: 2017.04.27
                    Time: 08:06:49
                    Voltage terminal 30: 12.5 V
                    CAN input signal(s) status-Transport mode: On
                    CAN input signal(s) status-Static current measuring mode: OFF
                    CAN input signal(s) status-Windshield wiper: OFF
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 0
                    CAN input signal(s) status-Wipe wash: OFF
                    CAN input signal(s) status-Rear window heater actual value: OFF
                    CAN input signal(s) status-Back-up light: OFF
                    CAN input signal(s) status-Actual value of windshield heater: OFF
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: 865810041700JQ
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 010FB031907D3A49E6-8054
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 567 955 119     HW: 567 955 119
   Component: WWS326 170104  051 0907
   Serial number: 887253F0401700400356
   Coding: 164DDD
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  042 0105
   Serial number: S5Y17M04D20H01M59S44
   Coding: 00885D
   Relative Air Humidity Interior Sender:
1 Fault Found:
527872 - Transport Mode Active
          U1105 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 61
                    Reset counter: 43
                    Mileage: 3 km
                    Date: 2017.04.27
                    Time: 08:06:34
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Part No SW: 3Q0 919 294 A    HW: 3Q0 919 294
   Component: PDC 8 Kanal   H07 0020
   Serial number: 000604177478080
   Coding: 0071151011
   ASAM Dataset: EV_EPHBO18VW3260000 007015
   ROD: EV_EPHBO18VW3260000.rod
   VCID: 377B1EE98E39B4F918-8062
Address 13: Auto Dist. Reg (J428)       Labels: 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0156
   Coding: 3200400150FF8728749C8065004087
   ASAM Dataset: EV_ACCMRRCONTIVW376 001011
   ROD: EV_ACCMRRCONTIVW376_VW37.rod
   VCID: 3B7302D9B2119099FC-806E
1 Fault Found:
0110 - Transport Mode Active
          U1105 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 25
                    Reset counter: 43
                    Mileage: 3 km
                    Date: 2017.04.27
                    Time: 08:06:31
                    Voltage terminal 15: 12.4 V
                    Control Module temperature: 31 °C
                    Velocity_vehicle_reference: 0.00 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.03 m/s²
                    Status_ACC_System: ACC_reversible_error
Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 AK    HW: 3Q0 959 655 AK
   Component: Airbag VW21   004 0306
   Revision: --------    Serial number: 003R6P7D5AMW
   Coding: 98CCC0C0000000005C5400CF00C800000065
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 071BAE29BE590479A8-8052
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 454 000 304 17
   Component: SideSensor_Df  008 0887
   Serial number: 35700000000738E0332C
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 454 002 903 17
   Component: SideSensor_Pf  008 0887
   Serial number: 358000000006FBD4032R
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 454 802 803 17
   Component: SideSensor_Dr  301 0148
   Serial number: 351002185CE0F000000N
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 454 802 903 17
   Component: SideSensor_Pr  301 0148
   Serial number: 35200B953CF0F000000.
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 5 - Part No SW: -----------    HW: 454 803 003 17
   Component: FrontSensor_D  304 0149
   Serial number: 35500AF8A820E000000.
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 3Q0 953 521 DQ    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0235
   Revision: FF035035    Serial number: 20170419400070
   Coding: 1414
   ASAM Dataset: EV_SMLSVALEOMQB 001015
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 020DBF3D957B2151FF-8056
Address 17: Instruments (J285)       Labels: None
   Part No SW: 565 920 740     HW: 565 920 740
   Component: KOMBI         211 8311
   Coding: 27A4091C2B80000801886A011001000800000000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_DashBoardVDDMQBAB 009051
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 56A5B36D29736DF1E3-8002
Address 19: CAN Gateway (J533)       Labels: None
   Part No SW: 3Q0 907 530 C    HW: 3Q0 907 530 C
   Component: GW MQB High   515 5286
   Serial number: 17041710802174
   Coding: 030100346F085700EB00024A1C0F00010001070000000000000000000000
   Shop #: WSC 33361 790 00114
   ASAM Dataset: EV_GatewNF 013020
   ROD: EV_GatewConti_013.rod
   VCID: 2F6B268976697C3940-807A
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0160
   Serial number: 000000000B1606110417
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5QA 915 181 C    HW: 5QA 915 181 C
   Component: J367-BDMConti  H03 1050
   Serial number: 7588610000170408130E
Address 2B: Steer. Col. Lock (J764)       Labels: 5Q0-905-861.clb
   Part No SW: 3Q0 905 861     HW: 3Q0 905 861
   Component: ELV-MQBB      H05 0032
   Serial number: 17000091377001
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarquMQBB 001007
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71EFE0F1A0DD2AC916-8024
Address 42: Door Elect, Driver (J386)       Labels: 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 E    HW: 5Q4 959 593 B
   Component: TSG FS        010 0032
   Serial number: 0000251725673
   Coding: 00158920D001040000001100
   Shop #: WSC 35110 377 09999
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 479B6E29FED9C47968-8012
Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 T    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 0107
   ASAM Dataset: EV_SteerAssisMQB 013144
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45876421C4D5D6699A-8010
Address 52: Door Elect, Pass. (J387)       Labels: 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 E    HW: 5Q4 959 592 B
   Component: TSG BFS       010 0032
   Serial number: 0000251399339
   Coding: 00158120D001040000001100
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 4685632DF9D3DD7193-8012
Address 55: Headlight Range (J745)       Labels: 7P6-907-357.clb
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0070
   Revision: --------    Serial number: --------------
   Coding: 03DE00003D210901
   ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
   ROD: N/A
   VCID: 418F7031D0FDFA49A6-8014
No ASAM data for: "EV_HeadlRegulAFSMQBMAX" (VW52)
Address 5F: Information Electr. (J794)       Labels: 3V0-035-MIB-HGH2.clb
   Part No SW: 3V0 035 021 D    HW: 3V0 035 021
   Component: MU-H-LND-EU   H50 0942
   Serial number: A674D0HS025755
   Coding: 03231601FF00000051111201008808102F0300C601200100DE
   ASAM Dataset: EV_MUHig4CGen2HBAS 001001
   ROD: EV_MUHig4CGen2HBAS_SK37.rod
   VCID: 2859CD9553872B0181-807C
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 565 919 605 B    HW: 565 919 605 B
   Component: ABT_Std-2_Nav  H35 8077
   Serial number: SKZ6ZHT1112419
   Data medium:
   Subsystem 2 - Part No SW: V03 959 801 JM    HW: -----------
   Component: ECE 2017  --- 0157
   Serial number: --------------------
   Compact Disc Database:
   Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2---  --- 1013
Address 6C: Back-up Cam. (J772)       Labels: 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H12 0231
   Coding: 04231601A2002017000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB_VW37.rod
   VCID: 397F18D1B82DA289EE-806C
Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: 31308402600000
   Coding: 1B08
   ASAM Dataset: EV_DeckLidCONTIAU736 001014
   ROD: EV_DeckLidCONTIAU736_VW37.rod
1 Fault Found:
0012 - Function Restricted due to Exessive Voltage
          U1401 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 43
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Voltage terminal 30: 12.59 V
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Part No SW: 5NA 035 284 A    HW: 5NA 035 284 A
   Component: OCULowMQBLGE  H13 0614
   Coding: 03231601EA423A0D3B1C9E000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 003042
   ROD: EV_OCULowMQB.rod
1 Fault Found:
12866050 - ROD - Unknown Error Code
          - 00 [008]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 42
                    Mileage: 9 km
                    Date: 2017.05.12
                    Time: 15:05:30
                    Voltage terminal 30: 12.4 V
Address BB: Door Rear Drv (J388)       Labels: None
   Part No SW: 5Q4 959 595 E    HW: 5Q4 959 595 B
   Component: TSG HFS       011 0032
   Serial number: 0000252669205
   Coding: 001881208001040000001100
   ASAM Dataset: EV_DCURearDriveMAXCONT 006001
   ROD: EV_DCURearDriveMAXCONT.rod
   VCID: 499F6811E8CD32097E-801C
Address BC: Door Rear Pass (J389)       Labels: None
   Component: TSG HBFS      011 0032
   Serial number: 0000252669204
   ASAM Dataset: EV_DCURearPasseMAXCONT 006001
   ROD: EV_DCURearPasseMAXCONT.rod
End-------------------------(Elapsed Time: 05:20)--------------------------
Hello, I also bought a short time Kodiaq 2.0 tdi, 4x4, dsg. Many long codes are not available, However, through the adaptation channel you can enter the control unit and modify the code.
I followed the octavia 3 procedure on the site and I "played."
If you need something in particular let me know if I can help you.
Marco
Hello, I can not find anywhere the translation of the long code of the abs control unit ..... I have to activate acc but I'm going to try ... Do you have something? thank you
Hello, can anyone help with the long coding of the 20th block -FLA / HBA, we need a long encoding from the factory kodiak
Marco
Hi Marco,
I am now to this forum and this topic. I want to change my map form EU to MRM (ROW) and have found google video on how to do it with VCDS. I went ahead to buy a cable to try it but the format is quite different from what I see in the youtube video.
Would you know how to go the the adaptation channel to change a map region code?
The instruction I found is open controller 37 (Navigation) or 56 (Radio), go to channel 130 in adaptation and change the value to 3. However, in Kodiaq, it seems 37 is not accessible.
Those instructions do not apply since the infotainment in your Kodiaq is at address 5F - those instructions are for previous generations of sat nav system.
Thanks for sharing PetrolDave. Would you happen to know exactly which address I need to modify to change the region code for map to southeast asia? As I am really very new to this, would be very grateful if you can instruct me how to get to the address space. I am using VCDS 18.9. I believe my cable is HEX-v1.
Found - 4th hexadecimal pair in the code-string of 5F module is the country-code for SATNAV. But do not know what is the hex value for southeast asia.
You really should keep your VCDS software up-to-date - it's free for all owners of genuine Ross-Tech cables! The latest version is 20.4.1
Sorry I don't know what the country code is for SE Asia either.
