Rear view camera retrofitted to SII L&K
16 hours ago, 26DIPP said:
R/W - Red / White.
You want a switched 12V. That is the power supply to the controller. If you only power the controller up when the car is in reverse the gateway will be throwing up errors all the time because it cannot contact the controller. I tapped into it in the A-pillar.
So I'm assuming that RW+ in the picture means rear wiper feed ,
  • Replies 52
  • Views 11.7k
  • I took the driver's seat off to get to the cable loom. The seat is held with 4 large Torx. To get to the loom you have to remove the phone controller and unclip the driver's seat electrics.
  • Calibration done. It had to be done with the calibration grid, otherwise the RVC STG would simply return an error message. I printed the grid as a poster and pieced the sheets together.
  • The handle will fit without the bracket. It has small plastic "hooks". Make sure you rust proof the cutout in the tailgate and then use a thin film of silicone.
22 hours ago, 26DIPP said:
R/W - Red / White.
the rear wiper fuse is a switched live , can i take the power from there then earth to car body :blink:
Ok
1/ put twin fuse into rear washwipe on fuse box then earth other cable
Edited by craigandrew
Did you read my reply?
I took the picture when I first bought the cable loom and was not quite sure about the wiring connections. I went through ERWIN wiring diagrams and loads of threads to get the answer. Try the wiper if you think it leads to a result. I can not help you on that.
Edited by 26DIPP
On 25/11/2018 at 18:02, 26DIPP said:
R/W - Red / White.
im asuming the R/W - Red / White. are on th iso that plug into the backof the headunit
and bat br go's tothe iso as well. ,
i have had a quote for fitting.
Never fitted a camera to a superb I would guess a around £360 inc vat
aes reto fit bristol
Could you please write all wire connections here? I dont understand where to connect other cables, (orange/brown and orange/purple from DVB-T and same from RVC unit) are they must connected together to Can L and Can H?
this is what ive found recently it should say on the top of your head unit witch conection is can hi and can low, pic belowe is just an example
Connection:
Orange - CAN High
Brown - CAN Low
Red - 12V
Black - GND
all i realy need to find out now is if the Red - 12V
ca be connected to the rear wash/wipe fuse as thats a switched live feed:wondering:
https://www.cars-equipment.com/www/en/shop/rear-view-cameras/oem-rvc-rear-view-highline-camera/
On my superb estate there is a 12v power supply socket on the n/side
Can you not take it from there?
I would not be piggy backing to a wiper supply
Just asking for trouble with these Canbus cars
Edited by DEL80Y
Connection:
Orange - CAN High
Brown - CAN Low
Red - 12V
Black - GND
If you want to do it in fuse box, then its OK, no problem.
I dont have this loom like in your link. Mine is exactly same like in this first post, with TV and RVC connectors.
As I understand then:
RVC connector and
2 x white - boot handle camera
Red/White - switched 12V+
Brown - Ground
twisted orange/brown and orange/purple - Can-high and Can-low (Columbus)
TV connector and
Red/Yellow - switched 12V+
Brown - Ground
twisted orange/brown and orange/purple - ???
Edited by janar
RVC connector and
Brown - Ground
TV connector and
Brown - Ground
yes im doing away with the tv tunner, cant realy see the point of it, you get rubbish signal from it and as im driving it would disable the tv tunner anyway,
RVC connector and
Brown - Ground
TV connector and
Brown - Ground
just a quick question
is your tv tunner plugged into your headunit then your tapping the cables into the plug that goes into the tv tunner, ???
spelling
i would really like to create a multicamera surround CCTV which recorded, dashcams are ok but only cover 1 angle
any ideas?
The orange/brown and orange/purple are the Can-supplies. They are a MUST and cannot be left unconnected. There are different Can buses in the Superb. Make sure you connect it to the corresponding colours.Or / Br Can low, Or / purple Can high Infotainment. Or / Gr Can high drive. Or / Sw Can high ....
The Red/White and the Red/Yellow are both switched 12V. I connected both onto a Red/White in the A-pillar.
Brown is ground.
You connect the components in the order:
Camera - TV Tuner - Camera controller - Columbus.
I'm assuming you mean the power socket in the boot.
That's 12 constant live,
Brown is ground.
Ware in the A Pillar,  Please
Brown is ground.
Thank you Gazdok, its helpful! I have only one problem yet. If you see my pictures, i have same colors in both twisted wires. I dont have or/gr cable. Which cables goes to pins 9 and 10? And if you know, what are the other pins? If I connect them wrong, what happens?
craigandrew,
I took the Red/White within the cable loom where it goes down from the fuse board under the floor carpet in the driver side footwell. Look at my picture 6.
Janar,
you should NOT have an Or/Gr in the RVC system. I just mentioned it, because it is another CAN bus system on the car. If you do not connect the CAN bus or connect it wrong the TV or RVC will not get and send the correct information to the gateway.
8 minutes ago, Gazdok said:
Janar,
So, both or/br goes to CAN-low and both or/prpl gos to CAN-high?
For most wires on the RVC only connect the same colour patterns. For R/W and R/Ge (yellow) they can go on the same as both are switched 12V+. Keep the Can buses as twisted as possible.
Tried to connect all wires as suggested, but nothing happened. I think that problem is in coding. If i tried to activate rvc with vcds, i have there only choise "rvc LOW installed" in navigation adaption. Did not find rvc HIGH anywhere.  After activating, appears on screen right bottom corner rvc image when shift is reverse. If i push on icon, then i see black screen only.
Any ideas?
I thought you have to unlock that in two different control units.
Which guide did you follow?
Check this thread:
This goes for high version, but I remeber when I coded my camera, I found isntructions somewhwre in net, searched something like B6 passat RVC retrofit VCDS coding.
Edited by linni
Check your connections again properly. When I put the Columbus back in after fitting I slightly dislodged the plug. Also check the controller in the back.
You have to go into Ctr 19, 6c, 10.
Have you got any DTCs?
Post an autoscan.
Edited by 26DIPP
This is an impressive job. Congratulations! I wish to able to do something similar.
How many hours you needed to do it?
Do you have also parking sensors?
Thank you linni, it helps! Finally  I got RVC picture on my columbus screen. But of course, now i have new problem - I dont have guiding lines on screen. If I look on VCDS backcamera adaptions then I see steering angles but on screen not even green box. Camera what i have is 5ND 827 566 C and RVC unit is 7N0 907 441. Is it possible to activate these guidelines somewhere or i have wrong spare parts?
Edited by janar
typo
I thought I have wrong camera and bought camera 5N0827566AB, but problem still exist, i dont see guidelines :(
