NSR Door Doesn't open
Evening all, For the last couple of weeks the wee beastie has been displaying a new symptom in that occasionally I cannot open the NSR rear door. Neither exterior or interior handle works but after locking/unlocking the car a few times I can open the door (trial and error). This evening however only one rear door was usable :angry:
Sounds like it may be a known problem. I've read about bowden cables and faulty deadlocks but can anybody offer some clues as where I should look first?
Edited by garibaldy
  • Replies 74
  • Views 6.1k
  • Wow, I've never seen that before, I wouldn't bother replacing the socket, just make a long jumper wire and send it round the plug and hide it in the rubber boot, if you ever have to remove the door yo
  • @garibaldy - Well, if the solenoid is trying to fire, I'd think it's either weak, or getting a low current. Either way, your investigation path starts in that door, and isn't in the driver's door for
  • On thinking of my reply... Its only actually practical if you get the door open! I think that you could intentionally disconnect the central looking to that door on discovering which wire it takes.
Happened to me once
try unlocking and locking the car a few times manually through the key hole, this worked for me
@garibaldy - Is there evidence that the solenoid on that door is trying to fire?
14 hours ago, greenineboss said:
Happened to me once
Just tried this but no luck :sadsmile:
Something is making a sound from the door for sure, but it didn't sound healthy initially. Rather than two distinct and solid noises from the other doors, the NSR was initially more like a grinding noise. I managed to get the door open but then locked it again as it's on a public road.
I've just been back out to the car and now the noise from inside the NSR door sounds the same as the others. However it will not open.
Edited by garibaldy
@garibaldy - Well, if the solenoid is trying to fire, I'd think it's either weak, or getting a low current. Either way, your investigation path starts in that door, and isn't in the driver's door for once.
After further investigation (ear against door skin this time) I'd say the solenoid isn't firing. There isn't anywhere near as much mechanical sound compared to the passenger rear door.
Also just sat inside the car using the keyfob to lock/unlock repeatedly and the lack of noise from the lock area of the NSR door is obvious.
Edited by garibaldy
Have a little look at the wiring in the door bellow to ensure they are not snapped or snapping!
The lazy tong riveter will be having another outing me thinks.
If i do manage to get the door open, is there anyway of disabling it's lock? At least if i get it open it will be easier to work on.
Try opening the front, feeling around the rear bellow and squeezing/manipulating it a little, as you try unlocking again. Mine is a MK2 but the bellow is accessible from the front door and the locks open/lock with the front door open. This MIGHT get the door open for you to investigate further!
P.S. Not Garibaldi 'cos your name is Gary and you are folliculy   challenged, are you?  (Another Gary, with a "High" forehead)!
Edited by mrgf
If i can get the door open I will be checking it out :-)
Garibaldi was a nickname whilst growing up! Surname is Baldwin and some clever git at a school must have had posh parents who liked fancy biscuits so that's one of the names that stuck. Garibaldy is more fitting these days :D
Nice one! My surname is FEAR... Yep, you read that right. Got a fair bit of stick as a schoolboy but suddenly became cool around the punk era!
That's cool :biggrin:
I had to do this recently, it was a ******, if you manage to get the door open you can remove the lock and disable the deadlock so you can refit the lock to shut the door but you won't be able to lock it.
The lock module is faulty, you must replace it, don't bother faffing about, just fit a new one.
If you can't get the door open then you'll have to remove the door card, the card will come off as long as you remove the rear seat squab, I had to attack the lock mechanism with a hammer and cold chisel to expose the gear so I could turn it to disengage the deadlock.
Not funny. You should have replaced it weeks ago when it started playing up but you could still open the door!
Always wanted a 3-door 6Y :D
Gotta smile as this car's keeping me busy, busy, busy.........Would be nice to have a break as she appears to be throwing me quite a few challenges!!!
Edited by garibaldy
Yep very cool surname!
forgot to quote.....
Edited by garibaldy
Yes, very cool surname!!!
  • Sponsor
I worked with a young lady one summer (1987?) whose surname was Wildblood.  Awesome surname.
Wonder what she's doing now.
Edited by Wino
I've started looking for a new module.
defintately a case od 'could've, should've, would've......'
Is this an MoT failure?
Yup.
It's why I had to do mine.
Can anybody confirm the correct part number(s) for NSR lock on a 6Y? I think it might be 6Y0839015.
Is the MK2 version compatible - looks like the only difference is a red v white plastic for the lock pin (which I dont have).
cool thanks mate.
