Octavia 2009 - rear door problems
Hello,
Suddenly my rear left door won't open I've almost destroyed door because im doing repairs with closed door.
I would be happy if anyone had a suggestion before i cut my doors in half with cuter.
Thank you in advance!
Dragan
Had this problem with old fabia, same principle
@Kris82Bro thnx for reply, I've seen this vid already month ago... doesn't work like that on rear door Skoda Octavia 2009.
I'm about to totally destroy door... any other suggestions???
Outside car....Banging the door just below handle while locking  then unlocking the car a good few times.
Or
Push the door into body while handle is open.
Edited by Kris82
Or
video to my problem, and what I've done so far...
Just seen video, Seems very stuck, but I would still suggest opening the handle from the outside and 'uncliping' the wire from the handle with a flat head screwdriver.
You've probably tried it though seeing how far you've gone.
I'd spray a **** load of wd40 into the mechanism now you got access to it.
Edited by Kris82
  • 1 year later...
I am currently at exactly the same point on the same door!
Did you ever manage to unlock the door, , I have attacked the actuator and I still cannot get it to unlock, my exterior door handle cable has released itself in the process and I am now only able to pull the interior cable,,,
I have been posting on another thread that I found similar, there is no where with a way to get this unlocked, complete nightmare
