ASR warning light coming on
ASR light is coming on with a ping after some time of driving.  It happened twice today exactly when I reached my destination.  It also happened another time but there was a loss of engine power.  Any ideas what might be happening?
I had this pop up at the weekend too. Came on with a ping. Turned the engine off and on and it went. Hasnt been on since but i did wonder why it came on
You don't say what year the car is, if and older car it could be one of the ABS sensors failing or corrosion of the ABS pick-up ring that they monitor.
It is a 2011 1.2tsi.
I noticed that it lights up when left idle for a few minutes with handbrake on.  I don't know if there is a link.  If i switch the engine off the light goes off upon restarting.
Mechanic opens next Monday therefore cannot link it up till then.
@GlueX - I'd suspect an ABS sensor since the ASR uses them to determine wheel speeds. It really needs a good fault code reader to determine which one is faulty though.
Update..... connected to computer and it showed that the ASR switch is faulty!!!!  Fault was cleared too.  Hopefully the issue will be settled with a new switch.
  • 7 months later...
I have this. Massive power loss when the ASR warning light comes on.    What do you mean by "ASR switch" ?
TC / ASR cuts power to engines as well as nipping brakes with systems that work.
You have a faulty system it seems and cutting power,   that is the ABS / TC (ASR) fault likely, the switch as being described here.
so that is not an engine fault, the engine is doing what it is told to..
Edited by Offski
It was not the switch on mine.  To be honest I still don't know what the problem was.  Took the car to an electrician and it was solved. When I asked I was not given a specific answer.  It just cost me 40 euros.
Apologies,  I said ASR  but the error that appears is  "FAULT: ESP"
On the dash, both the ASR and the tyres (with exclamation point in the middle)  warning symbols say lit up.
Does the above still apply?
Edited by spyshagg
Get it scanned for fault codes... That'll give you the best chance of figuring it out!
Yes, next week!  Thank you
I just wanted to go prepared so that they are aware I know what the problem might be.
@spyshagg - It doesn't make any practical difference; ESP still relies on the wheel speed sensors to tell it when to cut power, and when to apply differential braking across the axles.
Could you guys help me on this one?
It would perhaps help if we knew whereabouts in the world you are.
Europe, Portugal!
Have you had the car scanned using VCDS or similar yet?
Yes I went to the skoda dealership.     I didn't ask which was the fault code, but they told me the repair was over 2000€ because it needed a new ABS control unit.
Code J104 was the error
J104 is not an error code, it's the designation given to the ABS control module.
You gave 1K0 907 379 AH/1K0 614 517 AS as the ABS control module and pump part numbers. That's a MK60EC1 system which typically are very reliable.
I'd still be tempted to get the actual error codes before replacing the ABS control module and pump...
The dealership is quite far away, so I will try to download the VCDS software to get the code.
thanks for the help
Do you have a genuine VCDS adapter to use that software with?
I have an OBD2 cable I used in my old fiat stilo.   I already downloaded the software, I guess It doesn't hurt to try.
Edited by spyshagg
You need to have a read here: http://www.gendan.co.uk/product_VCHU.html
369 pounds.  I could buy 4 used  ABS control units for that price!
Thanks for the tip though.
