Performance monitor infotainment
Just a had a quick look at this and have a couple of questions.
Is there a way I can get the KW to show as BHP or PS ?
What max bar is the turbo boost stock ?
A bit of irrelevant info but fun ;)
Haven't found it yet either.....I just assumed that as 'BHP' was going out of fashion in place of kW that was what I was stuck with. :crying:
It would be interesting to find out If it was possible.  It's only a calculation to change.
Either way.  Kw is the industry standard for power, where ps (germany), bhp (uk and usa) and ch (france) are similar regional conversions related to engines, but not widely used outside these areas.
Well, thanks to Superbbte, at least I know the boost pressure should be circa 1.4 bar.
206KW is what the 280 is rated, but they should have it in bleedin' English for us lot, beggar "industry standard"  :D
PS is also used in Japan, its basically metric HP.
does anyone know if its possible to "enable" the Performance Monitor on non-Sportline models?
either via VCDS or OBDEleven.
The Skoda OneApp is a bit of a pain to use - cables, apps and all........
i have a 162TSi (220) DSG.
I know. Yes, it is possible via SWAP procedure. The problem is, Skoda will not sell the code to do it. That’s the end od story. Forget about it or just buy sportline.
If I mirror link my android device running the skoda app, it displays this kind of thing.
yeah, i was afraid someone was going to say this.
wishful thinking.
"just buy sportline" is not an option i have.
as per my post, its a pain in da a55 hooking up a usb cable, firing up SmartLink to open MirrorLink, and then open the Skoda One App, and then open up the "overview"!!!!
was hoping to cheat and get an easier path, like that in the Sportlines.
  • 1 year later...
Shame really, as I miss this from my B8 Passat!!!
