Dipped Beam Display
Hi,
Me again with the next question. I continue to compare FL3 with my old superb. When the headlights are on dipped beam should it show on the instrument cluster or does it just light up on the light switch cluster. Main beam displays on the instrument cluster. Fortunately I can normally see when the lights are on!!
Working correctly   :nod:
Pre facelift never showed on the cluster, only the headlight switch. Sounds like facelift is the same.
I also use the sat nav going into night mode as confirmation that the lights are on.
Edited by POWYSWALES
Thanks for the confirmation
