VW Caddy mk2 (Felicia) Pick-Up 1.8T
@D.FYLAKTOS This is all of the info on the front brakes which I found in TeflonTom's Felicia 1.8T transplant thread.
https://www.briskoda.net/forums/topic/209180-felicia-18t-transplant-thread/page/4/#findComment-2991830
https://www.briskoda.net/forums/topic/209180-felicia-18t-transplant-thread/page/4/#findComment-2991838
This is essentially the same as what I have told you already. The 'little spacer' which is mentioned as being required between the mounting lugs and the caliper carrier bracket is actually some chunky washers with a total thickness about 5mm. I had in mind that the holes in the mounting lugs had to be re-tapped for larger bolts, but I can find nothing about that in this thread so I am not sure now.
Next time I have a front wheel off my Caddy I will check the size of the caliper mounting bolts and confirm on here. I discovered that I have a 14" wheel here too, so I will try that and see if the Mondeo calipers fit under it. It is actually a Vauxhall steel wheel so it will not tell you definitively whether your 14" wheels will fit, but it should show conclusively if they will not.
Edited by Bete Noir
  • Replies 131
  • Views 60.6k
  • After the prang I had in April, the front end had been looking very sorry for itself. My preferred bodyshop managed to fit it in to get it looking more Caddy-shaped and get me back on the road, but it
  • Real progress   Once back together, it was treated to a liberal coating of stonechip
  • All the transplant bits which Tom had fitted to the Felicia with a combination of inspiration and perspiration were swapped onto the Caddy without requiring much of either (especially from me). The re
This Caddy has been in my ownership for almost nine years. The work that is documented in this thread I hope bears testament to the fact that it has never lacked for attention, and it has had more money spent on it than I would ever admit to my partner, but nonetheless there was still a shocking discovery to be made. Driving in and out of my workshop, up and down a small step / ramp I sometimes heard a noise like sheet metal deforming. More than once I had crawled over and under the pick-up in search of evidence of the source of this noise, but without success. The same noise occurred when I raised it using the scissor lift for the recent gearbox / driveshafts and brakes work, but now I could see dents in the side panels between the B-pillar and the rear wheels. This is not good!
Johnny from S&P Autos, who have now changed their name to Martlet Autos, had a look at the Caddy while it was on the lift in my workshop. It was obvious that it was not as rigid as it ought to be, but it was not at all obvious why not. There is a lot of new metal under there, and no sign of tin-worm, so the cause of the flex in the bodywork could not be identified. There were a couple of other jobs I wanted Johnny to do on it before submitting for an MOT test anyway, so we added further investigation of the structural issue to the jobs list.
When the appointment at the body shop came around, tactical jacking soon had the area of weakness pin-pointed, and a bit of expert poking unmasked the full horror.
The front lower half of the nearside rear wheelarch was not steel. Rust had eaten away the original metal in this area, and rather than repairing it properly the previous owner had put some effort into hiding it instead. The critical area where the wheelarch meets the sill, adjacent to the rear beam mounting, had been patched-over with fibreglass then painted with stonechip to complete the disguise. No wonder the Caddy was trying to fold in half!
NSR wheelarch fibreglass bodge
I want to stress at this point that I have never sought or received a ‘dodgy’ MOT for this or any other vehicle I have owned, and nor do I blame any of the MOT testers who have passed the Caddy during my ownership for not having spotted this horrendous bodge. Effort had gone into applying and painting the fibreglass so it looked like the surrounding solid bodywork. I can remember when MOT testers routinely used to run a hammer and a magnet over the underbody, which would have shown there was something very wrong, but I do not know of anyone who still does this as a matter of course. Without that this bodge was very hard to detect.
This photo was taken once the repair work was underway.
Getting back to how it needs to be.
Whilst the rear axle was hanging loose and out of the way, the opportunity presented itself to do some work to improve the top spring seats. They certainly look better for it.
At the body shop the work that I had done to tidy the hockey stick trims was completed, concluding with some nice gloss black paint. When the rear bed floor repairs were done they were finished-off with a covering of black raptor paint, but the tailgate inner panel had not been painted to match, and this was a good chance to rectify that oversight.
The Caddy looked better than it ever has previously, during my ownership at least.
There are a couple of results from the latest trip to the body shop which I neglected to draw attention to in the last update, one of which was a conscious choice while the other was unexpected.
I have never liked how the ‘hockey stick’ trims extend across the B-pillar. When I bought this Caddy these trims had been unceremoniously curtailed at their front ends, which caused some problems with water ingress to the load area, but was one of the previous owner’s visual mods which I did not hate.
Replacing these trims was an opportunity to do a better job along the same lines, and I had Martlet Autos cut and chamfer the front edges to follow the line of the cab back. In my opinion it looks like they are supposed to be like that, which is a positive sign.
The unintended outcome from the work to the rear spring top seats is that the rear ride height is now much higher. I need to get the back end up in the air again to make sure that the springs are seated correctly (there are no untoward noises to suggest otherwise), and if they are then I need to look again at lowering springs. I still have the springs I bought when I rebuilt the rear suspension, so it will be a little effort no cost job to swap them over.
This update is not about progress on my Caddy, but instead is about an event I attended. I was not there in the Caddy so the relevance to this thread may seem tenuous, but please bear with me.
Earlier this month I attended the Retro-Rides Gathering at Prescott Hillclimb. I was there in my SEAT Ibiza, and was lucky enough to be able to take it up the hill.
Wandering around the retro parking I saw these:
I would have really liked to have spoken to the owner of this one. The wheels appear to be the same Renault 16” steels which I have on my Caddy, and the paint colour is remarkably similar. I love the facelift front end too.
This last one is not my photo, so if the person who took it recognises it and objects then please get in touch and I will remove it.
The point I wanted to make is that when I bought my Caddy these Felicia-based pick-ups were mostly unloved, and you never saw them at events. This is clearly changing. There are now increasing numbers of Felica and mk2 Caddy pick-ups which have obviously had money and effort spent on them. I think this is great news, and if anyone reading this is struggling for motivation on their own project, I hope this helps.
On 13/07/2026 at 12:42, D.FYLAKTOS said:
I have 14" (factory were 13") wheels so dont know what options i have...
Sorry it has taken a while to check. It is not good news, the 14" wheel does not fit over the Mondeo calliper, even with the 25mm spacers which I have fitted.
Oh No, so i have to move on to 15" wheels and different set of tyres?
I cannot be 100% certain that there is no combination of 14" wheels and spacers which would fit over the 280mm discs and Mondeo ATE callipers, but I do not know of any car which has discs that size and runs on 14s. It is probably fair to assume that 15" wheels are a minimum requirement.
