Front and rear interior lights
Hi, just wondering if someone could point me in the right direction for a front and rear interior light for my octy vrs, I've seen the ones on super Skoda and was just wanting to know if I can pick them up anywhere cheaper as I think there a bit on the expensive side, both the front and rear on mine are broken, the two natural light looking ones either side of the main halogen looking one are working but the halogen looking one in both the front and the back are out, thanks in advance for any help
I got some from eBay. The seller sent me some that didn't fit, but then send me the correct ones 2nd time around (so not sure I'd recommend them!)
Can get a full set of overhead and boot LED lights for £15-20
Edited by Rjg
Ok thanks for info m8, could you send me a link to were you got them from and also do they dim like the OEM ones? Thanks again
LEDs are a massive improvement I found. When I put the old ones back in before selling it, they were so yellow. If you have puddle lights, make sure you do those too as it makes so much difference
Hi thanks a lot, can I just confirm that the top link is for the number plate lights and the bottom for the interior lights , sorry for sounding thick but I'm guessing the bulbs fit either the number plate lights or the interior? Like I say, it's the interior lights I'm needing bulbs for, want to change the two yellow bulbs and also the center bulbs of the interior lights aswel as it's went out, thanks again for the help
Also do they dim like the original interior lights when the car is locked
There are 3 bulbs in each of the interior lights - two 501's and a festoon. I'm pretty sure the festoons fit the numberplate too, but I think it's a bit of a hassle getting them to work with the error checking so I've contented myself with just doing the boot (501's), interior (4 501's and 2 festoons) and the mirror puddle lights (2 501's).
And yes, they do dim like the standard bulbs.
you were robbed if you spent even the smaller amount of £15.
Ok thanks alot
Ok thanks for the help, much appreciated, I hvnt got the puddle lights in the mirrors but will sure do my interior ones and boot thanks
Thanks tilt , so the 1st link you sent would fit the two reading lights either side of the the center light in the front interior light and then the 2nd link would fit the main center light in the front interior light? Or is it the other way round? Sorry for been a bit dumb but I've never had them apart to have a look, and also they dim like the originals yeah? Thanks for the reply
Edited by Catzeye
Festoon in the middle, 501's either side.
,and also they dim like the originals yeah?
You're welcome........................Or your welcome, as some would say, Lol
Yes and yes......................in my non face-lift, anyway.
