Cabin fan works but often no air comes our
Right I think I've worked it out. Car was running just on idle for maybe 10 minutes.
9.0 Evap temp was 07.0
10.0 evap temp was 30.0
10.1 liquid refrigerant pressure was 08.0. No idea if that's low or ok!!
  • Replies 62
  • Views 16.1k
  • All fitted and back together. Checked the menu for the Evap temp and it read 07.0 so a bit different to 33.6 from the other day. Anyway, just ran the car for half hour or so and the fan was working ok
  • My new G263 arrived today, at last! I compared resistances at various temperatures and found my old sensor drifted at all ranges but especially so at low temps. Hence the Climatronic didn't know the e
  • The G263 is a real pain to get to apparently, tucked up deep in the dash. I'll have a look at removal next weekend.
Try doing the diagnostic with the car cold after being sat overnight. All the temperature sensors should be about the same temp. There's 5 or 6 actual sensors from memory.
Have just taken my climate panel off and measured the 5 temperature sensors. Car has been sat all week so all 5 sensors should read roughly the same. 4 sensors were 23k +-0.5, one sensor was at 1.6k. No guesses which one. Obviously there a chance that Skoda chose to use a different type of thermistor for this, but I'm betting not.
New G263 sensor ordered and on the way.
I've just gone into the hidden menu again. Car sat all night. But I'll be honest I don't understand it.
9.0 = 00.0 Evap temp
10.0 = 33.6 Evap temp
10.1 = 03.2 refrigerant pressure
What do I check on the menu to tell if my G263 sensor is at fault?
If the car is all at ambient temperature, approx 5 degrees and not been running, there's no way your evap temp can be 33. Look at 6-1, 6-2, 8-1, 8-2 these are other temp sensors.
Ok I'll go check now and post back. Car hasn't ran since yesterday morning.
Just checked. I have
6.1 = 04.0
6.2 = 04.0
8.1 = 04.6
8.2 = 04.0
Out side temp is 5 °c at the moment according to maxidot display.
Fairly conclusive you have a requirement for a new G263. Obviously the climatronic doesn't know the evap is below freezing , causing condensation to ice up and restrict air flow.
Yeah the Sub menus you advised to check are vent and footwell sensors. As they are all reading roughly the same temp the 33.6 Evap temp does look out of place. So was the G263 sensor the one I mentioned behind the driver's side panel in the centre console?
I haven't gone looking for it yet. But it is tucked up well out of sight apparently. You might be thinking of the drivers footwell sensor maybe?
A job for tomorrow to track this errant sensor down.
The one pictured in the Haynes manual is fairly high up almost behind the climatronic panel. It's a grey sensor and according to them that's the G263 Evap temperature sensor. If you confirm if I'm right I'll order one. Thanks for your help btw we maybe close to a fix here!!
I'm not sure where it is to be honest. Some info say's it's high up and almost unreachable, some say it's low down. I don't know whether it changed position on the FL. There also may be an upgraded part that has a longer reach and is more reliable. I'll update this tomorrow when I find it!
The sensor I'm looking at in the manual is called a evaporator vent sensor. No mention of a G263 sensor. That maybe vag code. So not sure if this is the offending article. In the picture you can see the plastic piece to rest your left foot. This sensor is to the left of that. The manual also covers years 04 to 2012 no mention of f/l being in a different place.
Found the sensor, and it is easy to get to. At low level, behind one panel, to the left of drivers feet.
I've put the Bolero back in the car as a temporary, but that's not helped because the diagnostic data sets are numbered 11 to 35. I've not seen any online resource to explain those numbers.
That's what I couldn't work out. If say on 11 go with the second number. So that's menu 1 using the far left rotor switch then use the middle rotor switch for 1.1 or 1.2.
Just checked my display again pre f/l so yours might be different. Menu numbers start at -01. Right through to 32 iirc.
I can't find any reference to my codes. 16-4 @ 34 degrees was a point of interest, it briefly seemed to respond to manipulation of the evap sensor but then wouldn't play ball. Bolero is removed and everything put back together. AC recharge tomorrow, so I'll take it for a run in the eve and test it. G63 will be replaced midweek.
Centre console side removed and like I suspected the G263 sensor is right there. Twist and removed from housing. A lot easier than removing the dashboard!! Anyway, not quite sure what this means but I went into the climatronic menu with the sensor unplugged and the Evap temp reading went from 33.6 in to 42.4 unplugged.
No further forward today. Arrived at KF at the appointed hour only to be told that it was too cold to do it! Guess I'll have to wait fit the G263 to arrive.
I've ordered my G263 Evap sensor from tps today. Pick it up tomorrow and fit. I'll update here with new climatronic readings.
Do you have a multimeter? Would be handy if you could measure resistance at a warm and cold temperature.
Unfortunately not. The only thing I can do tomorrow is go back into the hidden climatronic menu and note what menu 10.0 is reading with the new sensor installed.
 Is there some reason you can't access your climatronic Menu?
Edited by meaty101
I’m following this post with interest. Last week travelling down the M1 to London cabin temp dropped and no matter what speed the fan was at there was practically no airflow. Read a post about resetting the flaps and that worked but only for about 5 minutes. Outside temp was between 5 & 7 degrees. Not a pleasant trip. Mine’s an 05 fl 1.9tdi elegance. Not sure if I will be able to see any codes, I have the mp3 & 6 CD player. Following this thread with baited breath! Ps how much is a new sensor?
First thing to do if the vent dies when travelling is to switch the AC off. This should allow the evap to thaw out and at least give you heated air. The G263 sensor is only approx £25 and when my new one arrives I'll be able to post a simple test routine for it.
G263 in hand. P/n is 1K09 907 543 G. My old part ends with A. Just having a brew then I will go and fit it and check menu no 10.0 and see what it's reading.
