strange error after updating bluetooth unit
Hi everyone!
I changed the bluetooth module under the passenger seat (driver seat for you in UK ;-)
The original was: 7P6 035 730 K
The new is: 3C8 035 730 E
Problem: I got a permanent error with VCDS:
01523 - Microphone for Telephone (R38)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 11
                    Reset counter: 115
                    Mileage: 0 km
                    Time Indication: 0
But the mike is perfectly working :-D
and I also get THIS:
                Address 77: Telephone       Labels: 3C8-035-730-A.clb
Control Module Part Number: 3C8 035 730 E    HW: 3C8 035 730 E
  Component and/or Version: Telefon       025 0983
           Software Coding: 040000000100010000000101
            Work Shop Code: WSC 12345 123 12345
              ASAM Dataset: EV_UHVPreim 002709 (VW36 *)
                       ROD: N/A
                      VCID: 2540C90824E1076ED9-8070
No ASAM data for: "EV_UHVPreim" (VW36 *)
1 Fault Found:
9458451 - ROD - Unknown Error Code
          - 00 [009]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 115
                    Mileage: 164912 km
                    Date: 2056.14.14
                    Time: 20:45:34
Still, everything is ok.
Any bluetooth retrofit guru able to understand anything? :-)
thank you!
Can you post a full autoscan?
If I recall there is a mic connection on the rns510 as well as the Bluetooth module, could it be reporting the 510 one missing but not needed?
sure!
Just I am wondering why NOW the error is not "unknown" and it become Cellular Antenna open circuit...
BTW, there's a windshield mount cellular antenna connected to the bluetooth unit... But I already have the shark fin waiting to be fitted, I could try to connect that and see if the error persists...
Tuesday,09,January,2018,15:09:35:00001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: TMBJE73T7D9038489   License Plate:
Mileage: 164910km-102470mi   Repair Order:
Chassis Type: 3T-SK46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 36 37 42 44 46 4F 52 55
          56 62 69 6D 72 77
VIN: TMBJE73T7D9038489   Mileage: 164910km-102470miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CFFB)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 JC    HW: 03L 906 018 BR
   Component: R4 2,0L EDC   X25 7129
   Revision: 42X25---    Serial number:
   Coding: 001D0012042400080000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_ECM20TD0I1103L906018JC 003001
   ROD: N/A
   VCID: 74E6E44CDFBB2EE69E-8020
No ASAM data for: "EV_ECM20TD0I1103L906018JC" (SK46)
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3520
   Revision: 05651213    Serial number: 00001212081807
   Coding: 0000024
   Shop #: WSC 33361 790 00999
   VCID: 2446D40CE7DBFE66CE-8070
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BL    HW: 1K0 907 379 BL
   Component: ESP MK60EC1   H31 0152
   Revision: 00H31001
   Coding: 843D601609250002210F06EC90220042350000
   Shop #: WSC 33361 790 00076
   VCID: 7DF0C168E4F16FAEE1-8028
Address 08: Auto HVAC (J255)       Labels:. 5K0-907-044.clb
   Part No SW: 3T0 907 044 BR    HW: 3T0 907 044 BR
   Component: Climatronic   H19 0607
   Revision: 00001007
   Coding: 0010000002
   ASAM Dataset: EV_Lcimatronic A01010
   ROD: N/A
   VCID: 0304B7908A15195E97-8056
No ASAM data for: "EV_Lcimatronic" (VW36 *)
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 AG    HW: 1K0 937 087 AG
   Component: BCM PQ35  H+  111 0709
   Revision: AD111709
   Coding: 40190ABBE85BF1C040080080710089E4437000AE736D81605C8140000040
   VCID: 76E2DE44C1C73CF6A0-8022
   Subsystem 1 - Part No: 3T1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 10121  26  0700
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 020113 05  54  0403
   Coding: 0630ED
   Subsystem 3 - Part No: 7N0 951 171 A
   Component: DWA-Sensor 00  002 0206
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
Address 10: Park/Steer Assist (J446)       Labels:. 5J0-919-475.clb
   Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0005
   Revision: --H11---    Serial number: 32961300701004
   Coding: 110115
   ASAM Dataset: EV_EHPVA14SKxxx0000 001001
   ROD: N/A
   VCID: 336427509A3569DE47-8066
No ASAM data for: "EV_EHPVA14SKxxx0000" (SK35 *)
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 3T0 959 655 D    HW: 3T0 959 655 D
   Component: J234__LD5 VW10 HI   2118
   Revision: 23018000    Serial number: 003LEPRWU44V
   Coding: 0017461
   VCID: 428A72941D8FD056DC-8016
   Subsystem 1 - Serial number: 6332MTS692473422
   Subsystem 2 - Serial number: 6342MTS666753422
   Subsystem 3 - Serial number: 6351HTS6R72GHBKR
   Subsystem 4 - Serial number: 6361HTS6842HHBKR
   Subsystem 5 - Serial number: 63727TS6TE9THBKR
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527)       Labels:. 5K0-953-569.clb
   Part No SW: 5K0 953 521 AT    HW: 5K0 953 569 B
   Component: LENKS.MODUL   014 0140
   Revision: FF010041    Serial number: 20130109800553
   Coding: 188A140000
   ASAM Dataset: EV_SMLSNGVLOWSXS A01004
   ROD: N/A
   VCID: 7EF2C664E1F774B6F8-802A
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 820000
No ASAM data for: "EV_SMLSNGVLOWSXS" (VW36 *)
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 3T1 920 841 K    HW: 3T1 920 841 K
   Component: KOMBI         H06 0608
   Coding: 111F01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
   VCID: 3B740F70B265A19E9F-806E
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 030113F1000091
   Coding: 359302
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H06 0608
   Coding: 000000
   ASAM Dataset: EV_Immo_UDSV_DD_RM09 A03009
   ROD: N/A
   VCID: 6ADAFA348D7FE81634-803E
No ASAM data for: "EV_Immo_UDSV_DD_RM09" (VW36 *)
Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664012607
   Coding: 010100
   VCID: 2A5A3A3445FF2816F4-807E
Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760 C    HW: 3C8 959 760 C
   Component: Sitzmemory    H05 2901
   Revision: 00H05000
   Coding: 00003B
   Shop #: WSC 12336 024 394758
   VCID: 356019489C4177EE69-8060
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 3T0 035 680 R    HW: 3T0 035 680 R
   Component: RNS-MID       H42 6276
   Revision: AB001001    Serial number: SKZ6ZZN50Z0086
   Coding: 04000400040000A11000
   VCID: 3F8C7B60AE7DBDBEB3-806A
   Subsystem 1 - Part No: 3T0 051 859 AQ
   Component: EU West V15  8515
Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H10 0415
   Revision: --------    Serial number: --------------
   Coding: 011D0220DE00001000
   VCID: 52AA42D40DEF40D66C-8006
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 196    3305
   Revision: 00H22000
   VCID: 377C1340464D85FE7B-8062
Address 4F: Centr. Electr. II (J520)       Labels:. 1K0-907-532.clb
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 050B0500
   VCID: 6FECEB20BE9D0D3E63-803A
   Subsystem 1 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H05 0220
   Serial number: 0123456789ABCDEFGHIJ
   Subsystem 2 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE20SKB13  H05 0220
Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H10 0415
   VCID: 51A84DD808E93BCE55-8004
Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0148
   Revision: 00H04000    Serial number:
   Coding: 1376839
   VCID: 3466244C573B6EE65E-8060
   Subsystem 1 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000021
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000021
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
Address 62: Door, Rear Left (J388)       Labels: None
   Part No SW: 8X0 959 795 D    HW: 8X0 959 795 D
   Component: TSG HL        H07 0415
   Coding: 010C00200000001000
   VCID: 50AE48DC03E332C65A-8004
Address 69: Trailer        Labels: RETROFIT69.lbl
   Part No SW: TCV 301 004 0    HW: TCV 301 004 0
   Component: ANHAENGER_MODULE TC 0030
   Coding: 0000001
   VCID: 458069880CA1E76EF9-8010
Address 6D: Trunk Elect. (----)       Labels:| 7N0-959-107.clb
   Part No SW: 7N0 959 107 E    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0243
   Revision: 41011001    Serial number: 338200954
   Coding: 082301C002
   ASAM Dataset: EV_HDSGSk462 301136
   ROD: EV_HDSGSk462_SK46.rod
   VCID: 39781578B859938E8D-806C
Address 72: Door, Rear Right (J389)       Labels: None
   Component: TSG HR        H07 0415
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105224674
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
1 Fault Found:
9458451 - Cellular Antenna
          B1053 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 115
                    Mileage: 164912 km
                    Date: 2018.01.04
                    Time: 20:45:34
End-------------------------(Elapsed Time: 04:45)--------------------------
I don't really have a clue.. can you tell me something more about this feature?
FIXED cellular antenna open circuit problem!
Disconnected the 5€ windshield antenna they give you with the bluetooth 3c8 unit, connected via fakra cable the shark fin one... error cleared and doesn't pop up again!
The microphone open circuit remains...
There isn't an mic open circuit in your log?
I did disable the "check mic" feature .. but as I re-enabled it, it immediately popped out.
   Coding: 04000402040000A11000
1 Fault Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 116
                    Mileage: 164914 km
                    Time Indication: 0
                    Date: 2018.01.10
                    Time: 14:44:32
I did some google research, RNS510 has a passtrough mic function...
If you have bluetooth, the mic is connected directly to the bluetooth unit under the seat.
If you have RNS510, you can have voice commands, the mic is connected to the rns.
If you haveRNS510 & BLUETOOTH, the mic must be connected to "mic in" on the rns, and the "mic out" from the rns goes to the bluetooth unit.
My car had bluetooth, but no navigation (I retrofitted the RNS), So I guess my mic is fed directly into the bluetooth unit, here's why the phone calls work fine.
I assume that voice commands should not work (but I neither even tried, nor I give a da*n), until I connect the microphone directly to the RNS (mic open circuit is showed because no mic is actually connected).
I'll do some more research and experiments, if my thinking is right, I'll deactivate the "mic check" function until I remove the rns to do something else, and fix this mic issue at the same time :-)
You're almost certainly correct.
You should be able to code the BT module for voice control but you'll only get phone related functionally.
