Cylinder 3 misfire
Good evening gents.
I recently bought a used 2005 Skoda Fabia 1,4l , 65 slow donkeys power. Milage of 138.000km
Today i had a sudden loss of accelleration while doing around 90-100km/h, the check engine light went on. A few more seconds after the car did not respond to the pedal at all, so i rolled down the hill and managed to park at the gas station on the bottom.
I stopped the car, and turned it back on, check engine light is gone and car seems to be in order. I completed the final 30km without any problems.
At home i did an OBD2 scan, came up with "Cylinder 3 misfire".
Anyone have any idea to what may cause this error? And should i expect another stop along the road in the nearest future?
Edited by havardr
A little edit here, its a 1,2L
Coil pack, swap 2 and 3 round to confirm, misfire should move to cylinder 2, if yes, replace cylinder 2 coil pack.
Thanks for the tip, I will give it a try.
I can't feel or hear anything on the car today, and the chek engine light went off as soon as i turned the ignition off and back on. Should i give it a swap before it happens again or wait until it does?
@havardr - It's virtually certain that your misfire is one of a bad coilpack, a bad spark plug, and bad LT cable to the coilpacks. Until it gets more persistent it's hard to say for sure which though.
  • Sponsor
Swap them now. Then when the light comes back on, scan it and see whether the fault is logged against cylinder 2 or 3. Cylinder 2 would be the better news.
