MY17 VRS Controller Identification
Ok fellow Briskodians looking for some help in identifying what each of the controllers in my MY17 VRS Combi are coded to control.
I think 5F controls infotainment but does it also code the maxi dot?
What are you using to code them? VCDS typically gives a good idea of what each module is in an autoscan.
5F is normally the headunit/radio. The maxidot will probably be 17.
Some changes will need coding across multiple modules :)
Unless it has changed in the facelift, maxidot should be covered by 17, Instruments/dashboard
Oh how dumb of me not to post that originally.
Yeah Im using VCDS. :blush::blush:
Thanks guys for the reply’s.
