Adaptive lights europe setting?
Hi,
I'm off to mainland Europe in a few weeks, does anyone know if the adaptive lights on a 2012 Superb has a setting to switch the lights to right hand driving? If so, how to change it.
Isn't it available on the maxi dot, under vehicle settings - lighting?
If it isn't there...its possible that they may switch automatically (using GPS if you have it).  I recall a thread in the last few days saying someone's MK3 moved automatically to European mode.
I recall in my MK2 there was a "Travel" setting in the Maxidot though.
I've found the travel setting, thanks. Not the best description for what it does
Yep I know.  I only found out what it was for after reading the manual!
If there is no option in the Maxidot - then there are small levers inside the lamps for manual switching.
Not on cars with adaptive xenons... It's either the maxidot method or a trip to the dealers to turn travel mode on :/
Halogen based cars may have a lever :)
