Need some help from you SuperB owners :)
Hi guys.
Could some of you help me with measurements of the airvent adjustments wheel in the dashboard? :)
I need to check out of if these wheel are same thickness than mine since I want to retrofit some wheels that can be illuminated hehe.
Thanks in advance
Best regards
Chris
C'mon guys?! - Not a single one that are willing to measure the thickness of the adjustment wheel you guys have for your airvents in the dashboard?
The stock vents/vent controls are lit, so if they're not lighting on your car you have a problem. Replacing the control dials will probably not solve this problem.
  • I know this, however I've got some spare time on my hands and want to try out if it would be possible to make the Superb wheels fit my airvent. I just need to know the thickness of the wheels before I order some used air vents that I can't use due to the thickness.
Tried some wheels from audi however these where to small in the diameter where superb ones are larger and may work :)
what car are you fitting them too?
and when you say thickness do you mean left to right or diameter?
FWIW the Passats have the same vents mine was a 2011 and had white rather than green illumination
I will try make the wheels work on the MK6 golf dashboard.
The measure I need is on the wheel itself. not the diameter or length :) The Audi wheels have a too small diameter to make it work but the wheels fit the whole in the mk6 airvent.
I will change the LED to a red one to make it fit the rest of the interior illumination.
8mm wide
