Factory bluetooth with RCD330G?
Hello everybody,
I'm thinking on a head unit upgrade. Currently I have a 2012 Octavia fl with factory fitted Swing radio and factory fitted-separate bluetooth module.
The spec of the RCD330G seems nice, however I'm afraid of the bluetooth phone capabilities.
  1. Will they work (the bluetooth in the RCD330G and the separate bluetooth unit) together? I prefer using the separate bluetooth, because I also have the factory fitted mic in the roof and I think it is better than the built in mic in the RCD330G.
  2. Will I be able to use the RCD330G as a Skoda Bolero? I mean the phone menu in the RCD330G will control the built in bluetooth module or the separate one if I have both bluetooth.
  3. Will I be able to use Mirrorlink? I have a Samsung SM-G361F and I'd like to see Waze on the RCD330G's display.
The RCD330 is not compatible with any OEM bluetooth module. It'll also be a different shape to a Bolero headunit so you'll need a new facia.
Mirrorlink is normally limited to 10-15km/h, Android Auto is a better option for Waze if your phone supports it.
There are a few different versions of the RCD330 which run very different software so be careful which you buy.
