ABS LONG CODING
Hi is there any way of getting a long code are a abs pump as iv change the one on my car as it come with out one but the last owners put the pump number down on a bit of paper and did not get the car scanned first i would be great full for any help
The part number for the ABS unit should be 6Q0907379G, it should also be coded 00044 for Bosch 5.7
If you have Bosch 8.0 it is totally different:
AZQ, BME:
6Q0907379R ABS 14” FS-III Drum brake 0000005
6Q0907379AA ABS 14” FS-III Drum brake 0000005
6Q0907379AF ABS 13” FS-II Drum brake 0002061
6Q0907379AF ABS 14” FS-III Drum brake 0002103
6Q0907379S TCS 14” FS-III Drum brake 0000005
6Q0907379AB TCS 14” FS-III Drum brake 0000005
6Q0907379AG TCS 13” FS-II Drum brake 0002061
6Q0907379AG TCS 14” FS-III Drum brake 0002103
6Q0907379AH ESP 14” FS-III Drum brake 0000428
6Q0907379T ESP 14” FS-III Drum brake 0000428
Edited by sepulchrave
  • Sponsor
Where did you find that info please sepulchrave? I'm looking at a scan of ours which has 6Q0907379AA  ABS 14" FS-II and drum brakes, which doesn't seem to feature? It's coded 0000005
S'OK, I've found it, but still can't see the combo we have. Maybe they refer to the FS-II front caliper system as 13" FS-II even when the car is built with 14" wheels on.
Anyway, to the OP, looks like you have the Bosch 5.7 system from your other posts, so should be coded 00044 as sep says above.
Edited by Wino
I think 13" means 239mm discs and 14" means 256mm discs rather than what wheels are actually fitted, you can't fit 13" wheels over 256mm discs, but you can fit 14" wheels over 239mm discs.
  • Sponsor
Yep, that makes sense. Brake description stating the smallest wheel size that could be used.
  • 9 months later...
Hi, can anyone tell me how to calculate abs long coding for Skoda Fabia 1.4 tdi,year 2009 with part number: 6r0907379e ,ESP 8.0 front h06, TMBBF25J093113835? Thanks in advance.
  • Sponsor
@Fikrie As it's a mk2 you want to be in that subforum and hope that someone there can help.
Thank you,i’ll try there
