Fault code help
Hi all got this fault code popping up every now and again it literally flashes up with a warning on the dash but dissappears just as quick but doesn't get stored on the infotainment unit any ideas? OBDeleven data log
Date: 2018-08-06 14:35
Car: Skoda Octavia
Year: 2015
Body type: Estate
Engine: CLHA 77 kW (105 HP) 1.6 l
Mileage: 61467 KM
16 Steering Column Electronics
System description: Lenks. Modul
Software number: 5Q0953507DH
Software version: 0110
Hardware number: 5Q0953549C
Hardware version: 002
Serial number: 11081404401969
ODX name: EV_SMLSKLOMQB
ODX version: 017001
Long coding: 1610
Trouble codes:
B116229 - Selector lever park position lock switch Implausible signal
Intermittent
Date: 2018-08-06 14:32:33
Mileage: 61466 km
Priority: 2
Malfunction frequency counter: 1
Unlearning counter: 88
Operating time: 100070 min
Supply voltage, terminal 30: 14.1 V
Vehicle speed: 51 km/h
Voltage at switch: 4.98 V
System status: 30
Terminal 15 status: active
Does the message say something about workshop and leaving it in P? If so, based on the message and error code I'd say it's probably the common DSG selector issue which requires the selector lever to be replaced.
Have a read of this thread:
Edited by ahenners
Lots of posts - known fault.
Ahhh thanks guys I will mention it when the car goes to skoda for its mot on Friday. The message does not stay on the dash long enough to read but from the quick glance I got that looks like it. As it's known fault what other issues can I expect?
From the thread theres no functional impact of this, just the warning message.
However, I guess its possible you wouldnt be able to start for the same reason if the error worsened (shifter must be in P to start) so its best to get it sorted while its at the dealers.
