VCDS Codings
Could someone direct me to/post a list of adaptions possible on the Kodiaq please. Can't seem to find very much if I'm honest in terms of content for Kodiaqs.
I belive anything on this list in the Octavia section can be done on the Kodiaq.
I have successfully done the neeedle sweep and the fan speed shown when in auto on mine.
Edited by Kenny R
Thanks. I managed to enable needle sweep and sign recognition yesterday after some more searching and working out what was similar to other platforms.
Will try fan speed auto show as well
... and how do you do this.. coding?
You need to buy a special cable (£200 - £300) and download the software...
www.briskoda.net/forums/topic/229766-vcds-adaptations-how-do-i/
Use Obdeleven. Much cheaper and has the functionality to do the same codings.
Or find someone local to you with a cable and come to an arrangement...
I haven't done any more coding yet as haven't had the time. But yeah I use Obdeleven as it works out cheaper than a typical VCDS cable that the majority of people use.
If you don't really want to get too into coding etc. Cheaper and easier to ask someone local to you to do it in exchange for a few beer tokens. Also depends what you want done as well :)
Either way if you like to enable and change stuff the typical owner can't then it's pretty much the only way
Is there a list of basic coding that can be done?
For example... Needle sweep can be added
See the third post in this topic.
  • 1 year later...
Previously used VCDS, with no problems. Now I bought newest cable version 19.6.2, but can't access adoptations in central electronics module, this button is like not active - grey. I inserted security code, it is accepted.
Also long coding is not working, all is filled by 00000.
Is here some other security or just my cable can't handle it?
p.s. car is Kodiaq MY 2019
See post #2, you'll be better off asking in the dedicated VCDS section...
You have Chinese clone.
The original works perfectly.
+1
oh ****, never will buy something like that in ebay again! :D  ok, will look for original one in local market. Thanks for responds!
