which diagnostic tool do i buy for a 1.6 tdi ?
As title, there are so many out there for sale.
That might depend on how much or how deeply you need to use that sort of tool, for easy to use and lots of jobs Carista is fine, for more involved stuff VCDS is still top of the pile for DIYers who are serious.
Thanks for your prompt reply, car has gone into limp mode and i need to find out why, i retired from the spanners before computers took over, so it just needs to tell me where the problem lies.
I dont use a phone so it would need to read codes and display. Any links to one would be appreciated thanks.
I'd sorry that is the best that I can think of, the trouble can be that there may well be many OBD2 scan tools that are quite cheap, but they will only decode emissions related engine fault codes, what can be a lot handier is a scan tool that is VW Group specific as it will reveal many more engine codes and then there are the other VW Group specific ones that can decode all codes from all small controllers. It is just finding a point to stop at and still have a useful scan tool.  Gendan is a good diagnostic tools seller to talk to if you have any doubts of what a scan tool can or can't do for VW group cars       https://www.gendan.co.uk/
Edit:- hum, not much "mid range VAG specific" scan tools in Gendan's list now!
Edited by rum4mo
Many thanks  rum4mo, I see wont you mean.
I was recently eying up a icarsoft product, can't quite remember the actual part number but can't be hard to find. They do a VAG specific unit that has a bit of gumpf for around the £100 area. VCDS will run into hundreds but is worth it long term, if you are an enthusiast. The VCDS plugs in to a laptop, whereby the icarsoft is a self contained unit. I believe it is upgradable so a good second option, depending on the depth of your pockets!
Edit, its the icarsoft i908.
Edited by mrgf
I bought a Snap on one today works well, no3 injector was found to be the fault.
...Any more info on the tool. Functions and the price?
Snap on Solous Pro 2015 used but like new.  £450
Anyone tried OBD Eleven on the fabia?
Now to make it work for its money?
Very true its about the same money for the injector, unless some one knows to any cheaper.
Xman, do you mean OBD11? its roman numerals for two, not eleven.
Oh, I got you... Not the standard OBD scanners that plug in to the OBD!! port. Doh!
Edited by mrgf
Anyone know the torque setting for the injector retaining bolt please.
Bump
bump again.
  • Sponsor
Which engine code?
CAY from memory.
Many thanks Wino, I can now proceed,
  • Sponsor
Pleasure mate, let us know how you get on. :)
new injector and bolt fitted today, all seems back to normal. Thanks for all the help chaps.
Do you not had to re-code the new injector with a VCDS?
no need to re-code.
