Oh Presh!
Tire pressures , prob talked loads on this forum.
I was running around for a few weeks with 32psi in the fronts and 34 on the backs. Ride seemed good , soft.
I checked the psi recommendation for the least amount of weight 235x 40x 19" , 2 people and a bag or 2 , it said 2.5 bar. Checked what that was in PSI and it turned out to be 36 psi
So filled the air up to 36psi. Man its now stiff, hits all holes and is a miserable ride.
So wot do you guys do, what do you recommend?
Ps changing the fronts to Michelin PS4S very soon
Don't think a couple of psi should have made much difference. Are you sure you haven't inadvertently pumped up to 3.6 bar?
