revesing camera question , again
has anyone used one of theses harness adapators in link belowe
https://www.aliexpress.com/item/Car-Smart-Reverse-Camera-Interface-For-Audi-A3-Volkswagen-GOLF-7-With-Parking-Guidelines/32819521851.html?spm=a2g0s.13010208.99999999.259.30453c00wYSTw2
Car-Smart-Reverse-Camera-Interface-For-Audi-A3-Volkswagen-GOLF-7-With-Parking-Guidelines.jpg_50x50.jpg this one says on other web sites no coding required
This video interface works on standard 5.8 " and high 7"/8 " factory screen For AUDI A3 / For Volkswagen GOLF mk7 / For AUDI A6 / A7
*It has one way front view camera signal input for add external front camera accessory.
*It has one way rear view camera signal input for add external reverse camera accessory.
*With active parking guidelines system,moving by steering wheel.
*With OEM radar sensors detection showing on screen.
*Automatic switching to rear-view camera input on engagement of reverse gear.
*SW DIP switcher setting to choose resolution 480x234 or 800x480.
*Compatible factory monitor both 5.8 inch ,7 inch or 8 inch screen.
*With 4pins round LVDS connectors output to original screen.
*OEM power cable plug and play installation,do not need to cut any of original wires.
                                  __________________________
                               it says plug and play ie no coding
Edited by craigandrew
Just to ask, do you already have a camera that you wish to use or not? For that price, you can get the genuine camera (low version, all the required cabling)
I think the OP wants to add moving display lines...
Not sure if it's work on a MK2 Superb as it's only listed for MQB cars.
where to ive looke eveyware;)
On 06/10/2018 at 13:23, langers2k said:
will these actually bolt up to a mk2 kombi? I would love to install a rear camera in my 2013 4x4.
They're replacing the existing boot central handle switch, go for the RGB one (has the direct cable for the Columbus)
@pablomax I think the cameras I posted are:
- Overall L/W/D  111 x 49 x 58 mm
- Installation opening L/D  101 x 42 mm
Measure your boot handle to make sure it's the same size and double check with the seller :)
does this work on all models or do you need some sort of specific BCM etc? if all am going to have one i think
Lowline cameras with static guideline don't have a control modules. They should just need power, ground, reverse light connections and plugging in to the Columbus headunit.
After fitting, the headunit will need coding.
