Is it easy to split the dashpod?
Ross? I think I may need a tiny chat in MSN. ;)
Just want to be able to get to behind the screen, I fear. :(
Oh dear, starting a little project are we? :rofl:
Any sign of a new job btw?
Just want to be able to get to behind the screen' date=' I fear. :([/quote']
I hope you havent put an engine through that screen as well :eek:
No - Just got MOT coming up and I'm getting fecked off with a certain breakers based up North.
if they don't get their act together I'm going to name and shame them, :grumpy: But I have the ABS light on, and they're sending me a sensor I need..... Last resort, split dashpod and bit of black tape or remove the bulb. That will be acceptable. :)
No removing bulbs i'm afraid J. LED's all the way.
You need to be careful not to break the plastic front on the pod.
How does it come off though? Is it kind of bonded on so I need to warm it up to get it apart?
Jason, it'll still fail the MOT if no ABS light comes on. It needs to follow a sequence, like on for 3 seconds when ignition is switched on. Not sure what your's is but each make has different sequence. Do it properly, wire ABS light to the charge light!! It works a treat on my car!
