Dtuk box Causing epc light and limp mode.
Hello
 I am on my second dtuk fsr+ box. The first one caused constant epc lights and limp mode. Spoke to Andrew at dtuk and He requested I sent it back. Recieved a replacement straight away.
Now after two months the same problem has come back with the new box. Soon as i put the blanking plug on i never recieve any problems, so I quess this rules out the wiring loom?.
What do you guys think should be my next step.
Many thanks in advance
What settings have you got it on?
 I have tried 2+2, 1+2 and 1 +1. All settings bring epc light. Almost like the car judders  a little bit after a couple minutes of driving. Could bad fuel be causing the issue? But as soon as box removed the car is fine.
I dont know about Petrol but it seems the diesel is alot more robust. I have to push very hard in x+2 or x+3 to get any lights.
what are the errors showing up as in VCDS? low pressure on the rail etc? it could be a very sensitive sensor on the air or fuel?
Edited by JohnnyType2
As JohnnyType2 said, see if you can get a scan on vcds or obd11, that would be a start I guess
Yeah I've had this cold start juddler issue before, went after a software update from Skoda but, returned recently however, I don't get EPC light
Could a boost leak be causing this? Or bad fuel Maybe. Seems to only happen at low revs with the box installed. Last night I reinstalled the box and went for a spirited drive and no problems occurred. The setting I used was just the standard of the program 2. Not sure why I get the epc light sometimes.
Edited by hazzaardous
Yeah low revs on cold engine for me usually, when the wife is in the car !!!
I'm only running Vpower nowdays so I can't think it's fuel, had the problem previously with OEM air intake & now with a big Revo cone setup so, I don't think it's a boost leak.
Are you now on the App controlled version of the tuningbox ?
I'm still on the version before, maybe a software upgrade would help? But my car is out of warranty now so if I was going to do that maybe a proper map would be better ?
When I had my previous box, I'm pretty certain It was boost errors, i will have to get it plugged in again to check. I thought the sensors only plug into camshaft, upper boost and lower boost? On the fsr+ box. Could this cause low pressure on the rail then? Just the problem is resovled with the box completely removed.
  • 5 weeks later...
feel free to give me a call during office hours and ill look into this for you
