Second remote key required (Superb II)
Hi chaps and chapettes
Picked up a 2nd hand Superb Estate Elegance 1.8TSI (11-reg) a few weeks ago, and unfortunately it only comes with one key. After a search on the forum, it seems like there are a number of options including dealer (expensive) or a local auto locksmith.
Having done a bit of research online, I've come across http://www.car-keys-online.com/. Apparently they do everything remotely, including cutting a key using just a picture of the key! (I don't have the key code). Has anyone used them before? Any red flags that you can see? Can't find a truspilot entry/reviews for them so unsure at this time.
Any support is appreciated!
They aren't going to be able to code it unless they have your vehicle or parts from your vehicle.
I had a suspicion that £50 for a replacement key was too good to be true ... presumably I'll need to go to someone like these guys: http://duplicut.co.uk/
Thanks for the heads up!
Look up Auto Solutions on Facebook.
Thanks for the suggestion. Do you know where they're based? It appears that Auto Solutions is a very popular name for car companies - facebook search is giving me loads of hits, one of which is in Bermuda! :biggrin:
Craig Nettleton is mobile, he will add you to a list and then comes out to an area and does several keys at the same time.
Where did you get a second key cut and coded in the end? I need to do the same.
Not yet I'm afraid. Still intend to buy Christmas spending has taken priority for now! Will report back once I've had it done.
