Rear door seal?..excessive wind noise!
I've noticed excessive wind noise from the nearside rear door on my Furby....I know its a problem with a seal but which one? and does anyone know the part-number for it?...I want to give my local dealer as much info as possible as I dont want to make repeated trips to them as I can only get there on a saturday!
any help much appreciated!...as always:thumbup:
Are you absolutely sure it's the seal? Have you had anyone sitting in the back pulling on the door whilst going along. It may be down to door alignment if the door sticks out a bit (hinge side) then that can cause a right ol racket!
Chris
is the window done up?
Yep has someone sat in the back playing with the window and doing various things to the door but to no avail...door is pukka fitting, no sign of accident repair etc!...I will have to have another look!..maybe take the trim panel off!
thank u both:)
Yep has someone sat in the back playing with the window and doing various things to the door but to no avail...door is pukka fitting' date=' no sign of accident repair etc!...I will have to have another look!..maybe take the trim panel off!
thank u both:)[/quote']
If it were a seal, then someone tugging of the door, would almost certainly stop the noise. I'd say it was highly likey to be the door alignment... Do you get a lot of dirt coming in on the shuts, may be worth a look!
