Intermittent multiple bulb failures
Good afternoon,
Has anyone ever had 12 bulbs fail simultaneously, and then come back online without any corrective action? A couple of failures were near side rear indicator, front offside indicator, numberplate illumination, reversing, brake, offside dip beam and a couple of others. Current train of thought is possible dampness somewhere, failing earth, or, slighty more off piste, one of the rear dual filament bulbs failed or failing. The last one fron mk3 escort experience many, many years ago!!
VCDS scan shows individual failures but no commonality.
Any ideas greatly received.
Should add that this is on the estate, just to make sure there is no confusion.
Edited by Canders
Sorry can’t help you but my octy2 2005 is moaning about OSF headlight then you drive down the road and it’s working again. I swapped the bulb and the new one doing the same. Annoying.
Battery replacement needed perhaps always throws odd errors on cars. Well documented here. A type 096 from ABS eBay will only set you back about £60 for a 4 year warranty. And fits perfectly, albeit oversized compared to factory. That’s a diesel spec one.
Gav, battery only 6 months old and this fault has occured twice within the last month, hence the "damp" train of thought as the weather down here recently has been pants.! Your issue definately annoying, could it be the holder loose?
Might be worth adding your autoscan to see exactly what the faults are.
At a guess, it might be a fuse issue. I'd check the engine bay fuses are secure and clean as water ingress isn't as uncommon as it should be :/
Langers,
Checked and all are dry/secure.
Took the dog out and the defective lamps went down to 5 errors!!!. Have checked all the lamps in the rear nearside cluster as status reports all 4 errors in rear nearside, the 5th error was a service due message, and all appear intact. However, the upper red side light glass appeared darker than the rest. Unfortunately my fluke has gone walkies so cant check the actual resistance, that ill have to do tomorrow. From your experience, could an intact lamp filament, but possibly of a high resistace, cause such an odd fault?
Just a thought - are all the failing bulbs connected via a common harness point, such as the feed that goes to the tailgate which exhibits failures to fatigue failure of the wiring?
Good point, another area of investigation tomorrow in daylight, I did look for a common earth point but must admit, failure of the actual wiring loom did not cross my mind.
Sure, if a bulb is about to fail, the electronics might be able to detect it even though the bulb is still working. It's certainly done so in other peoples cars.
I wouldn't expect one bulb to cause the original 12 warnings or the 5 warnings you now have. It feels much more like something which would be common to all such as the power feed to the control module or the ground point. Given it started with 12 warnings, it's more than is fitted to any individual light cluster so I wouldn't expect a single ground point fault to cause that many codes.
Obviously there could be more than one fault ;)
An autoscan showing the original 12 and current 5 warnings would be great. At least it should help narrow down any shared power/ground feeds.
Edited by langers2k
formatting
With a break in the weather, scanned with the results below. Further observations:-
Set off for morning dog walk, 9 errors!! Returned from morning dog walk, 9 errors indicated initially, however upon pulling into the drive, no faults indicated and all lamps working.
Saturday,01,December,2018,10:50:21:52226
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN:   License Plate:
Mileage: 186780km-116059mi   Repair Order:
Chassis Type: 1Z-SK35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBHS21Z6A2062983   Mileage: 186780km-116059miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 TB    HW: 03G 906 021 AN
   Component: R4 1,9l EDC  000SG  2047
   Revision: --H11---    Serial number:
   Coding: 0000071
   Shop #: WSC 73430 790 00999
   VCID: 72EA555D6D6323DAD3-8026
1 Fault Found:
012295 - Camshaft Position Sensor (G40)
               P3007 - 000 - No Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00110000
                    Fault Priority: 0
                    Fault Frequency: 254
                    Reset counter: 255
                    Mileage: 170698 km
                    Time Indication: 0
                    Date: 2017.09.18
                    Time: 06:28:01
             Freeze Frame:
                    RPM: 315 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 9.96 V
                    Bin. Bits: 11000100
                    Idle Stabilization: 0.0°KW
                    (no units): 3.0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
   Component: MK70 M MASR         0104
   Revision: 00H35001
   Coding: 0017665
   VCID: 7BF478793A29629280-802E
No fault code found.
Address 08: Auto HVAC (J301)       Labels:| 3C8-907-336.clb
   Part No SW: 3T0 820 047 M    HW: 3T0 820 047 M
   Component: Climatic      150 0303
   Revision: 00006001
   Coding: 0000000002
   ASAM Dataset: EV_Climatic A01005
   ROD: EV_ClimaBasis_SK35.rod
   VCID: 3978A271B8959082D2-806C
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 AD    HW: 1K0 937 087 AD
   Component: BCM PQ35  H   111 0709
   Revision: AB111709
   Coding: 40180AB8B85BB1C04848008015000024476000AE525D81605C4440000000
   Shop #: WSC 73430 790 00096
   VCID: 73E45059D2792AD2D8-8026
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 29100  22  0601
   Coding: 00DFB7
   Subsystem 2 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 3 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
9 Faults Found:
02395 - Parking Light Front Right (M3)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 2
                    Fault Frequency: 18
                    Reset counter: 220
                    Mileage: 184622 km
                    Time Indication: 0
                    Date: 2018.10.05
                    Time: 08:58:15
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.90 V
                        OFF
                        ON
                        Term 50 On
                        ON
                        OFF
00979 - Lamp for Low Beam; Right (M31)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 1
                    Fault Frequency: 4
                    Reset counter: 2
                    Mileage: 185921 km
                    Time Indication: 0
                    Date: 2018.11.08
                    Time: 14:55:21
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.35 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01504 - Bulb for License-Plate Light (X)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 2
                    Mileage: 185921 km
                    Time Indication: 0
                    Date: 2018.11.08
                    Time: 14:55:21
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.35 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00987 - Lamp for Brake Light; Left (M9)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 4
                    Mileage: 185940 km
                    Time Indication: 0
                    Date: 2018.11.09
                    Time: 06:36:38
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.35 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01499 - Bulb for High-Beams; Right (M32)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 1
                    Mileage: 185921 km
                    Time Indication: 0
                    Date: 2018.11.08
                    Time: 14:55:22
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.25 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01518 - Bulb for Back-Up Lights; Left (M16)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 5
                    Mileage: 185921 km
                    Time Indication: 0
                    Date: 2018.11.08
                    Time: 14:55:23
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.25 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00927 - Terminal 30 (Right)
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 1
                    Fault Frequency: 70
                    Reset counter: 5
                    Mileage: 185921 km
                    Time Indication: 0
                    Date: 2018.11.08
                    Time: 14:55:53
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.25 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        ON
00985 - Right Tail Light (M2)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 2
                    Mileage: 185940 km
                    Time Indication: 0
                    Date: 2018.11.09
                    Time: 06:36:39
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.75 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
02394 - Parking Light Left Front (M1)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 2
                    Mileage: 185940 km
                    Time Indication: 0
                    Date: 2018.11.09
                    Time: 06:36:39
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.75 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2GX9E.
   Coding: 0020788
   VCID: 3D70B66164BDACA2FE-8068
   Subsystem 1 - Serial number: 6332MSME4A4027075
   Subsystem 2 - Serial number: 6342MSME4C22293DJ
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Component: J0527           056 0111
   Coding: 0000702
   Shop #: WSC 00000 999 209715
   VCID: 76E2694D010B3FFAFF-8022
   Subsystem 1 - Part No: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO   H07 0012
   Coding: 00000130
   Shop #: WSC 00000
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 1Z0 920 943 S    HW: 1Z0 920 943 S
   Component: KOMBI         H06 0608
   Serial number: 00000000000000
   Coding: 710900
   Shop #: WSC 00152 210 91233
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
   VCID: 4998D2B1E875000242-801C
Address 19: CAN Gateway        Labels:. 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0231
   Revision:   H16       Serial number: 4320K09B02028C
   Coding: E9807F06000202002303
   VCID: 69D8323140B5E00262-803C
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H06 0608
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADA4D3D8DB3EB1A6B-803E
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2114
   Coding: 0000756
   VCID: 489ED7B53B7FF90A5D-801C
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 68     3001
   Revision: 00H17000
   VCID: 31689A51A8E558C26A-8064
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000756
   VCID: 479CD4893661F67254-8012
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
   Component: BOLERO        008 0053
   Revision: 0A001001    Serial number: SKZ1Z3I8176322
   Coding: 000004000001
   VCID: 3560AE419C8D74E236-8060
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 73430 790 1012551
   VCID: 326A955DADE363DA13-8066
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 3364905952F96AD218-8066
End-------------------------(Elapsed Time: 02:01)--------------------------
That looks like a power issue to the BCM. Feels like it might still be a loose fuse or water ingress in the fuse box.
It would also cause the bulb warnings shown :-)
If the fuse, no12, 5A I believe, was affected by water, would that not be a short cct as opposed to open cct? The fuse box itself was bone dry and the fuse good. There was a little moisture below the actual box but nothing of major concern. Currently no faults and all working again.
If the power input was disconnected due to a bad/loose connection, I'd expect an open circuit fault as above.
If the power input was grounded, I'd expect a short to ground/short circuit warning and the fuse to have blown.
I'll try and check a wiring diagram tomorrow to see if that gives any clues. 5 amps seems too small for all those lights.
I would suggest you take a good luck at fuse 16 (30a) in the engine bay. From the wiring diagrams and owners manual, it's responsible for powering most the right side lighting on the car so fits with your fault codes perfectly.
It might just need the connector cleaning up and squeezing slightly to ensure good contact. Check for micro-fractures in the fuse too as they can cause intermittent failures.
The one you mentioned (fuse 12, 5a) seems to be for the CAN gateway rather than the BCM :)
Langers,
many thanks for that, tomorrows job. I'll have to update my info as well.
Another good test would be to clear the faults then remove the fuse and see if the same ones come back, that should confirm if it's a likely cause.
Langers,
If I ever get over to your neck of the woods, I owe you several pints!!
Fuse 16 was the issue. No moisture no damage, however, the fuse blade on one side of was dull grey, just heavy oxidation, quick rub with the edge of a coin, replace and all was well.  As you suggested, cleared the faults and scanned to prove all was good. Removed the fuse and re scanned again but cleared all the faults. All bulb faults cleared, but the fault indicated as terminal 30, remaind as expected.
Again, many thanks for all your help.
No worries, glad it appears to have been something simple :)
if you would like to see some examples of logical fault finding in modern vehicles, have a look at youTube South Main Auto.  The guy does great videos of fault finding and the logic behind what he is doing.  He's personable too, which helps make them watchable.
Well done on the fuse.
  • 1 year later...
On 04/12/2018 at 05:33, Canders said:
Langers,
Canders and Langers - I have many pints for both of you.
I had the identical problem to you Canders: 12 light faults (in seemly random locations) all appeared spontaneously one day, then disappeared after an hour of not driving.
They then failed again recently, a few weeks later, and had remained like that the past few days.
I literally just tried copying the same fix of taking out Fuse 16, cleaning some dullness/light corrosion with contact cleaner and some fine grit sandpaper and incredibly all the faults disappeared!
I am absolutely gobsmacked how easy a fix that was.
So sincere thanks to you both for the post and the solution respectively.
Cheers!
Great result @PanoramicSounds - glad to help and that it was a nice easy fix :D
  • 1 year later...
Hi all, I'm a new member directed to this site by Google after experiencing the same issue with our newly bought 2010 Octavia Scout. Not sure of the exact number of failures but it was at least the o/s headlight, one front side light, one rear sidelight, rear number plate light, and two indicator bulbs, during a period of heavy rainfall here in Wales In 40 odd years of motoring I've never experienced anything remotely similar. Very pleased to find what I hope will be the answer on here and will be attending to it later today.
We don't have a manual for the car so I was wondering if anyone might be able to tell me where the notorious Fuse 16 is located? Thanks in advance of any help.
Wow, that's great thanks, I'm guessing the one I'm after is in the engine bay box rather than the Climatronic fuse 16 in the cabin, thanks very much indeed for that info. 16 looks a bit lonely up there with only 17 for company.
You're welcome, let us know how it goes.
I'll be giving it a go in the next hour and will send an update, thanks again.
While I'm on, the missis is complaining of a low frequency noise at low revs which has started in the last couple of weeks and which I'm guessing must be exhaust related. Is this a common thing with these cars? We've only had it a little while. It's a 2010 Scout CRD, with around 93,000 miles. We love it apart from these minor issues.
