1.2 TSI stutter/jerk
So. Got the car back today. Spark plugs and leads changed. Car has ran totally fine since picking it up.
No rattle when stationary and no stuttering in gear. Fingers crossed it stays that way
  • Replies 54
  • Views 19.4k
  • I'd advise you to immediately buy a diagnostic scanner, here's a cheap one   https://www.carparts4less.co.uk/cp4l/p/-/-/-/-/?548775301&0&t5_399&gclid=EAIaIQobChMI-eiw
  • If you bought privately, you're stuck with it, otherwise the Consumer Rights Act applies.   https://www.theaa.com/car-buying/legal-rights   Get the car scanned for error codes, tha
  • There may still be "Pending" fault codes. For instance a misfire will be logged, but if it is an isolated incident it wont put the EML on.   https://www.nyvip.org/PublicSite/OBDII/diagnostic
Hope no WD40 was involved.....:whew:
That will remain to be seen, I may get Skoda to look at it to see, would they be able to see if the actuator is on its way out our is it a case of once it goes bang you know, my 3 months warranty has been reset from today's date too so if it's as you say then would hopefully raise its head in that time frame
Impossible to check actuator problems until they actually happen.
Good luck and enjoy the car.
You have 6 months by law as I stated earlier if this issue reoccurs.
  • 8 months later...
