FAO: those with Josh's engine guard.
How does the alloy guard attach to the car? My brother in law has asked me to get a similar thing made at work for his Calibra :thumbup: The chassis has a number of holes that I could use for rivnut type bushes but I dont have th etools for that.
I assume rivnut tools are not part of the standard Fabia tool kit so how does Josh's guard fix to the vehicle?
IIRC is uses exsisting bolt holes.
As in, bolts into threads that have nothing in them or those intended for the plastic guard (if there is one)?
Goochie,
I think the thread in the GB section has a fitting guide if that helps any. It bolts on using the original mounts that the plastic cover uses and two bolts that I'm guess are in the main chassis frame (holes and thread is already there)
Will there be any more GB's for this?
I may know where you can get one if needed.
pm sent
