KW ST Coilover Kit. SOLD
Yes, I know it's too early to start selling things, but come on, it's time to start thinking of your cars again.
As you will see I have a set of KW ST Coilovers for sale.
They came off a Roomster Scout 1.9 tdi. This is a brillient set up, but not for towing a caravan, that's the only reason they were removed. Will come with new front adjusting rings.
Ref No KW ST 132 82 020  there selling at £600 at the moment.
For Sale £175. Pick up from the Coventry area.
Edited by NZ100
Wonder if these will fit a mk1 Fabia?
What age was the Vroomster?
Hi J, 2008.  i think the fronts will fit as Roomster is Fabia front. I had a set of Bilsteins on at one point and someone bought them for a Fabia. I'll try and look back and see if i can find who had them.
Hi J, tried to get in touch with the other Fabia member, but doesn't look as though he's on the site anymore.
Ref No for front 800 1011
                    rear  800 1104.
Anyone interested. If your too far away, could look into courier, at cost.
  • 4 weeks later...
Hi, i am interested in them but so you know if they fit a non scout roomy, 2008 1.6 petrol is my tank.
Checked on their site and the part number is compatable, there are x2 same kits, 1 max axle weight is 900kg and 1 in 960kg and there is nothing to indicate a difference, all list the same roomies as compatable, your is the 960kg ones. are scouts heavier and need higher rated parts? i recon its okay, any thoughts
I just looked at the KW site as well, and it does list your car the same reference as mine. .
I recon they'll be okay, maybe lol
How long did you run them for and did you need shortened/adjustable ARB links? looks like they can take a chunk of lowering on standard ones
I'm in S Wales so will be looking to have them sent down, what will you take total with sending them down here? Coventry's just too far for a stroll right now.
I ran them for 2.5 years.
Didn't have to change anything else.
Don't know cost of posting.
Do you know of any couriers?
Anyone on the site know???
Posting depends on the size and weight, they'll collect from any address you want, can book through places like
https://www.parcel2go.com/services/large-parcel-delivery
i recon £20 to £30 quid? depends on the weight and size you can box them up, i guessed 30kg and 150x75x50cm.
PM sent.
