Front seat heating problem
Hello,
I have a problem with the heating of the front set... I turned on the heating but the seat remains cold. Except that there is some problem with the heating elements, could be maybe any other simple solution for this topic? Any experience?
Gone
Edited by FlyingSpanner
1 hour ago, FlyingSpanner said:
Have a look a bit further down, someone else is discussing this issue which may help you.
But in short check both switch selectors light up, if they do the front seats only have one supply fuse 20A so if only one seat not working, it can’t be the fuse. Also is it the backrest or the seat base not working? If both, it’s unlikely both elements will fail at same time so indicates a feed or earth issue. Next logical thing would be to make sure the connectors are in place under the failed seat.
Thank you for your help! I can't find the other discussion, could you please give me the link to it?
Both parts of the seat are not working. I will check the connectors later today on your advice. Could you please tell me, if you know, where can I find the fuse? In the motor box or in the interior fuse box?
Gone
G
