Octavia parking sensor alarm
Octavia Mk3 - Sept 2014
I've started getting a loud alarm from the back of the car after breaking and if driving slowly - sounds like i'm about to reverse into someone and it'ts real close. The parking sensor button by the gearstick also flashes. With the car parked pressing the parking sensor button shows a diagram of the car with exclamation mark by the front bumper.
I borrowed a laptop with an old copy of VCDS on it and ran a full scan, it shows
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 17.1.3.0
Data version: 20170203 DS267.2
www.Ross-Tech.com
Mileage: 24794km-15406mi   Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: ******************   Mileage: 24794km-15406miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 61884000000516
   Coding: 1A078A9124242974007B060341C8245851249400608224F00023F072C002
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1USDContiMK100ESP 033001
   ROD: N/A
   VCID: 44809752CF009F618D-8010
No ASAM data for: "EV_Brake1USDContiMK100ESP" (SK37)
1 Fault Found:
16401 - ROD - Unknown Error Code
          - 00 [008]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 243
                    Mileage: 24407 km
                    Date: 2018.11.14
                    Time: 10:48:01
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 F    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0047
   Revision: --------    Serial number: 39431418600491
   Coding: 0131061041
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_EPVHA2CAU3700000 003019
   ROD: N/A
   VCID: 428C914AD5149151BF-8016
No ASAM data for: "EV_EPVHA2CAU3700000" (VW37 *)
2 Faults Found:
1111812 - ROD - Unknown Error Code
          - 00 [009]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 7
                    Reset counter: 238
                    Mileage: 24772 km
                    Date: 2019.01.11
                    Time: 10:37:09
1112324 - ROD - Unknown Error Code
          - 00 [009]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 7
                    Reset counter: 238
                    Mileage: 24772 km
                    Date: 2019.01.11
                    Time: 10:37:09
Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0189
   Revision: --------    Serial number: 003P4PCRKCKJ
   Coding: 98CCC000000000005C5400CC008800000065
   Shop #: WSC 73430 790 00123
   ASAM Dataset: EV_AirabVW20TS6VW48X 001116
   ROD: N/A
   VCID: 7F0AD8BEE6663CB990-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 307 14
   Component: SideSensor_Df  008 0887
   Serial number: 3576U0000000A705401Z
   Coding: 2D2D2D
   Subsystem 2 - Part No SW: -----------    HW: 454 003 006 14
   Component: SideSensor_Pf  008 0887
   Serial number: 3586U0000008D4154012
   Coding: 2D2D2D
   Subsystem 3 - Part No SW: -----------    HW: 454 803 006 14
   Component: SideSensor_Dr  111 0148
   Serial number: 3516R1FED0D04000000G
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 454 802 906 14
   Component: SideSensor_Pr  111 0148
   Serial number: 3526R4B430E04000000/
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 454 802 105 14
   Component: FrontSensor_D  114 0149
   Serial number: 3556V83ADB103000000D
   Coding: 2D2D2D
No ASAM data for: "EV_AirabVW20TS6VW48X" (SK37)
1 Fault Found:
9682162 - ROD - Unknown Error Code
          - 00 [008]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Mileage: 10250 km
                    Date: 2016.12.17
                    Time: 09:19:13
Any idea what the fault code might be (and likely apx cost to fix)
The airbag one I'm not ever so bothered - a dozy twit decided to overtake everyone on a roundabout then - being on the right of me when her exit came up - tried to drive through my car to make the turning (my dashcam including sound recording from satnav disproved her story that I made an unexpected manoeuvre)
...  the VAG approved repairer drove the car in the workshop without the door fitted.
All the parking sensors are ticking quietly.
Edited by peterhr
add car model / year
If you update VCDS to the latest version it will probably tell you what the error codes are.
16401 - Crankshaft / Camshaft Position Correlation Sensor B Bank-1
1111812 - Front Left Parking Aid Sensor
1112324 - Front Right Center Parking Aid Sensor
9682162 - Multiple collision brake
HTH
Thanks gRoberts :)
What has 16401 - Crankshaft / Camshaft Position Correlation Sensor B Bank-1 got to do with ABS Brakes??
Can you buy parking sensors pre-painted?
2 hours ago, peterhr said:
Thanks gRoberts :)
Lol absolutely no idea but the 16401 code is shown on other scans within the abs controller.
Ive now got the sensors and am seeking the opportunity to fit (or get them fitted).
Interestingly the fault comes and goes - seems strange that two sensors are faulty or none?
Anyone got views?
