581 Bulb (LED)
Dimming will mostly depend on the LED driver. If it doesn't support PWM dimming then I doubt a resistor will help.
When I fitted LED fogs to my Octavia, one would dim much more smoothly than the other and I had a bulb warning error. After using ODIS-e to code the LED fogs in, both dim normally and the warning is gone.
  • Replies 55
  • Views 7.5k
  • I have this LED's and they are great: https://www.aliexpress.com/store/product/Canbus-Error-Free-No-Hyper-Flash-Amber-Turn-Signal-BAU15S-BA15S-PY21W-1156-S25-LED-Bulbs/1396454_32945895534.html?spm=211
  • Hi!   No problem. No, for $15 you get one pair (2 bulbs). Description is wrong.
  • They look good! Two pairs ordered!
On O2 or O3?
9 minutes ago, Krunoslav said:
On O2 or O3?
Mk2 FL. It's a '61 plate or MY12.
Interesting, I will have a look in VCP to see what can be coded
I have one problem. How to disable cold diagnosis via VCDS on o2 fl? I get only option to disable it on licence plate.
By using ODIS-e or VCP to directly edit the EEPROM.
