Bend light malfunction?
Amber bulb warning, said 'bend light not functioning' any ideas?
There is a problem with the afs system for the xenon headlights.
At a guess, it could be water ingress to the control module under the headlight as it's happened to others.
Probably worth getting it scanned with VCDS or similar to confirm.
+1 !!!
Edited by drefaldwyn
+2!
Thank you for your advice, re VCDs, do I have to go to Skoda dealership for this check?
 @omnipeta check locally for members first
Edited by DEL80Y
