oil change
just about to do an oil change on my 1.2 TSI (2014) how do I reset the oil change warning message on my screen, (not maxidot)?
I would like to know if it works in practice. I have this print out but not yet followed it. From what I understand if you are on Variable servicing this method changes it to fixed servicing.
a) While the car ignition is turned to off, press the 0.0 button and while pressing it turn on the ignition, but do not start the engine.
b) After that release the 0.0 button and press the MIN button which is the left button (the one used to set the time.)
c) Turn off the ignition key and release the MIN button and that is it.
Let us know of  your success.
PS I have other instructions which say that hazard warning lights have to be switched on
Edited by edbostan
Yes it works fine, I think I only pressed the min button once, and then released it thank you. I,ve just found it on Youtube for a Fabia
