Cornering fogs
13 minutes ago, ExSEAT said:
@Maggle in fact ignore the post above, its incorrect!! Just had a look at the car and this is the setup instead...
The 'ignore' post which @Maggie refers to has now been removed to avoid confusion.
Oops. More confusion from me as that should obviously have said @ExSEAT's post! :blush
Edited by john999boy
I've taken the plunge and placed an order. Just got to wait for it to arrive now...  :)
A nice touch on the ODBeleven is the history folder, every change you make is recorded & date/time stamped, so if you do get things wrong its quite easy to go back to were you started
Unless you use the dreaded 'apps' :o
