Blu tooth Elm
Ok If someone could help please.
I have borrowed my friends bluetooth Odb11 reader for the reason that I think my car lacks power and boost.
So iv connected the odb11 and used the boost widget and im only getting a boost of around 12.25 psi
My car is remapped to stage1 revo.
Now my next question is. with it being bluetooth and not mechanical like a boost guage, will it give a correct reading if there is a boost leak???
Please help x
Edited by drew_smith
It will report the level of boost as seen by the pressure sensor and that would be that same as any external gauge, if there is a leak they will both show a low level
Thanks very much. that confirmed my suspicion.
But my next question!!
What should a revo stage 1 remap produce. taking in mind iv just jad a brand new borg amd warner genuine k03s turbo fitted
9psi is stock. The K03S turbo peaks, in some tunes, at 20-21psi, the Revo should be hitting 18-19PSI at full boost.
Edited by sakta
Mine is definitely under boosting then.
I can hear a hissing from the right hand side when I accelerate
You probably have a boost leak, unfortunately finding it is a bit of a phaff and will take some time. It’s fairly common. If you cant find it with a visual inspection, there are a few videos on YouTube detailing how to find it
Edited by sakta
yeah iv seen some videos on making a boost leak test kit.
Think I will go that route
