Skoda Fabia MK1 speaker replace
Hi
Mine front door speakers are broken and i got an replacement for them with spacers/adaptors.
I wonder if i can connect OEM tweeters or do i need to replace tweeters too?
I got this KIT https://www.brl.se/sv/artiklar/gas-alpha-65-tums-kitsystem.html
I just wonder if i really need to replace the oem tweeters or can i just install the midbass and get stock tweeters to work like now?
My HEADUNIT is SONY cdx gt420u
If the tweeters sound ok then leave them, if not then disconnect them.
Use your own ears, I can't hear it from over here.
Thanks for your answer. I just wonder if it works to use stock tweeters or do i need to add new tweeters that came with the package? There was 4 cables connected to the speaker and 2 for the tweeter. Can i use 2 of them for midbass and 2 for tweeter or do a need do it other way?
I notice a small box in the kit shown in the link which I assume is a crossover unit, if you want to use this unit you should replace everything following the instructions provided with the kit, only two of the connections to the original speaker will be the sound signal from the head unit, the other two probably go to the tweeter.
Yes sir that is right there is a 2 small crossovers  and only 2 cables Red and Red/Brown are there when removing Tweeter.
So now i need to connect Midbass to the Red/Redbrown cables from HEADUNIT and those other 2  cables from new tweeters? Should i connect them on same cables as Midbass?
Edited by bihslk82
So i need to connect Midbass to the Red/Redbrown cables and those other 2 from new tweeters? Should i connect them on same cables as Midbass ?
You need to connect the crossover input directly to the head unit, then the two speakers to the crossover outputs separately.
I assume there are six connections on the crossover.
Nope its not. Only 2. 2 Inputs and 2 outputs.
I talket to the store now where i got the KIT and they said that i should connect tweeters on same cables as midbass i dont need connect to the headunit directly
Edited by bihslk82
Ok, do that then. Good luck.
thanks for the advice
