DIY Service
Evening,
I was was wondering if there is a complete guide to performing your own minor service?
I have a a VRS which I get serviced every 10K miles/1 year. It’s a 220 TSI DSG (2013)
Im thinking of doing this myself now to save a bit of money, I plan on keeping my car when the finance is up which isn’t long away.
Is is there a comprehensive list of tools needed or can someone help?
I would like know:
Oil Litre Capacity after draining
Nut size to remove oil filter
Replacement Sump Plug part no or where to source
Sump plug tool
Any other parts needed
Cheers,
Stu
A metric socket set with torx bits, plus a torque wrench to make sure anything you take off is as tight as it should be. Halfrauds socket sets are very good. Plus keep your receipt as they have a lifetime warranty which they do honour.
Parts can be found on the likes of eurocarparts. Give a ring to any motor factors and they'll know what you need.
I'd invest in a set of ramps so you're able to get under the car that bit easier. It's also that bit safer than trying to use a couple of jacks and axle stands.
Only major thing you'll need is a device of some descript to reset the service time. OBD11 device or VCDS will do the trick.
Cheers TuneDude.
Any idea about the sump plug?
6 minutes ago, StuFan said:
Cheers TuneDude.
not sure mate. That's where having a butchers in a motor factors comes in.
I'm sure there's a workshop manual for our cars..........I'm struggling to find it. That would be a good starter for you
Thanks  Nige
Hi Stu, it appears you may have the same car as me (EA888 rev3 CHHB engine), so I believe this is the sump plug you require would be this one and of course you will need the removal tool which can be purchased here.  I have to admit, I have yet to do my own oil service on my vehicle but being old school I like to change my oil every 6000 miles. On my old Mk2 Octavia I had a quickvalve fitted, but unfortunately at the present time, having emailed them, they are not available for the Mk3 TSi. Hope this helps.
Paul
Edited by Extreme3d
Paul
Hey,
Ive ordered all the bits I need apart from the removal tool. Online and looking at some guides it appears you can use a flat ended screw driver for removal so will do this.
Cheers!
I'm sure my sump plug on my 2.0d is a bolt, not torx.  Also the service reset can be done through the settings on the head unit (certainly can on my Columbus)
It's a plastic sump plug in the TSI I believe and needs to be changed at every oil service.
Aah ok, must be different then
I generally do all my own servicing but as my Octavia is a lease car I won't be touching it. However, it's worth getting yourself on GSF and Euro car parts email list as they often have promotional deals such as 60% off.
No doubt someone will be in here slating off both these companies but their deals on recognised brands of engine oil (of the correct grade) are often well worth having.
I will be the one that slates them then :D
e.g 5 litres of shell Helix HX8 is listed at a ridiculous £66.99 and with the bank holiday discount you get that down to a more reasonable £36.84.
Ebay are selling Qantum delivered to your door for £25.
Case closed.
