ABS and Skid lights
I have a 2007 Fabia 1.9 diesel and afer about 12 miles the ABs ans Skid lights come on switching the ignition off cures it far a bit
I have cheched the code and comes up with this
Part no 6Q0907 379 AG
MABS 8.0 Front H02
Any ideas please?
That part number is the ABS module itself, it would help if there were a specific fault code.
@Terfel - I see where @Wino is coming from. When you switch on, does the charge light illuminate?
  • Sponsor
Actually not a conclusive test for this Ken. The blue exciter wire is what makes/doesn't make the battery light work. The (broken) DFM wire is what puts on these other warning lights after 10 minutes of driving.
Often if one is broken, both are though...
Got the hang of  carport software
00290 left rear and wheel sensor
0120 abs valves voltage supply
As I only have the free software unable to erase
Any ideas the price of the  software?
Ok you should definitely check the load signal wiring as has already been suggested, you may also need a sensor but fix the primary problem first.
Thanks all for your help
Will have a look in the morning
