Bolero (62 plate Yeti) - Options to upgrade Audio
In my 62 Plate 4x4 Yeti I have a Bolero head unit, which although it has a "Phone" button doesn't seem to have bluetooth built in.
Ideally, I'd like to either add to on or replace the head unit to give me phone call support and bluetooth music streaming. Anthing beyond that (Android intergation, google maps, reverse camera, etc) would be good but not essential.
Before I bought this car, I'm sure I read that there was a website I could visit which would give me all the options available - but now I can't find / remember it.
Anyone know what I mean?
DaveA
Edited by DaveAber
Adding a BT module and wiring kit is easy enough. It should be coded with VCDS to make sure it's correctly installed afterwards. That'll give you calls and streaming with the right module.
Later Yeti headunits had BT built in and Android Auto support. You can fit one but you'd need a wiring loom adaptor and to have component protection removed.
There are also various aftermarket options, some will be the same size/shape as the Bolero, others will be double din sized so you'd need a facia adaptor.
All depends what you really want and how much you're happy to pay!
Is it easy enough to work out which BT module is compatible with the current head unit? - would that be one that lives under the driver's seat which my previous (newer) Yeti had? (16 plate)
I don't have VCDS (yet) but am planning to get a 3-VIN one, so happy to code as required.
"Later Yeti headunits had BT built in and Android Auto support. You can fit one but you'd need a wiring loom adaptor and to have component protection removed."
  - interested in this as well (whichever option is cheapest  easiest vs the features you end up with) - Not familiar with component protection - is this a Skoda thing to stop you simply adding new parts to older cars? Is removing it a VCDS function too?
What I'm sure I had found and now can't is a site where all of the various options were not so much available on a menu but you could email them and they would offer the various potential options / solutions. No idea now though, it was over a month ago and my memory doesn't work well in that range!
i would like to know too, how can i identify the part number of the BT module, and how can i coding it. it needs some wires and mic too? My yeti is my2011.
