I need Bolero Update :-)
Old check your PMs. @oldjohn ghost screen is 99% HW issue, digitizer to be replaced.
  • Replies 1.2k
  • Views 218.9k
  • My friends used to say: Point 1 - Pawel is always right Point 2 - if Pawel is not right then check point 1
  • All check your PMs
  • Sent via PM.   Guys you need to tag me if you want a link as I don;t have time to follow forum on regular basis... I drop me a PM.
To be clear what mean when I say “ghost screen”, things happening like Siri asking me what I would like to say to people in my contacts, or even starting calls randomly, neither of which I have requested, as though a ghost is working my Bolero. Is this hardware? The other thing I’ve been seeing is constant cycling of the starting Apply Play via usb message, until I reboot the Bolero, after which it works normally when I re-attach my phone to the USB.
Hello! I have 5q0035840C
H41
Sw: 0456
Does anybody has updates?
I've got issue disconnecting android auto. Sometimes it's happen when USB cable slightly moved inside the socket.
Thank you very much pab567!
But I can not get the system to detect the firmware. I tried 3 different USB memory sticks. 8GB, 16GB and 128GB. I formatted them on Windows and on Mac as FAT32. I unpacked and placed the content in root on the drive. I tried updating from the Menu > Settings > System menu but also by holding the Menu button for 5 seconds. Bolero does detect the USB stick but absolutely not the firmware. The "select source" menu is all greyed out - CD ROM, USB Memory and SD Card. It's a Skoda Fabia so there is no CDROM or SD Card.. just a USB connection. I have updated this Bolero once before in 2020. It worked fine back then. Before it was on version 353 and I updated to 367. The update that I can't get to work is the 369. Is there a bug in 367 that prevents from detecting firmware on USB?
Of course there is SD slot, it is located inside the glove box. Look into your car manual. Basically do not use USB but SD and follow the procedure:
1. format SD (max 32GB) under FAT32
2. unpack to root (metainfo2.txt and all the folders must be placed directly on SD, not in any folder)
3. insert SD card into the slot
4. enter Service Menu (long press MENU button)
@pab567
Hello, I got a Skoda fabia 2016, do I need to upgrade my system?
Thanks.
No clue why the picture is upside down, tried to rotate and it still uploads it that way.
Edited by Gamur
PM
Thank you! I found the SD card slot and the update went fine!
Hello,
i need a Update for my Fabia 3 (2015)
Current information:
Device number: 5Q0035840A
Hardware: H24
Software: 0241
Media code: 2101.0.0.8
Can someone send me a Updatefile or Link
Thanks a lot
Greetings
@pab567 hey! My software is on 8740, I’ve been told that 8742 is no longer available and that I need 8755, do you have the link for this please? My CarPlay constantly skips and pauses and I’ve not been able to use it since I bought my car! I’ve attached a photo of my system software, 2018 fabia colour edition IMG_3633.jpeg
Check your PMs for download link
Hi @pab567 , i have this version.
Do you have an upgrade?
The system crash every day ☹️
Thank you
There is no newer version for your firmware. How does it crash?
Some days it's all ok, other days it doesn't work. The dispay turn on, on the Skoda logo but don't start. Even if I wait several minutes. When the system doesn't work, also the usb doesn't work (don't charge telephon or other.. No electricity comes out)..
This doesn't look good - intermittent failures are the nightmare for analysis and finding the root cause. Having a log could help but for this you need PC connected with UART to the unit when it fails.
Hello @pab567 , i am also interested if there is an Software update for my Skoda Fabia 2015 Bolero.
Edited by soemon
PM
@pab567 Hi, is there a newer software for my bolero? I have a problem with the Smart link connection. Sometimes it can't connect via cable.
PM
On 10/08/2019 at 19:34, JoePeddos said:
Hi HingAmHang I have a Skoda Fabia 3 SEL 4.2015 with Bolero built before week 22 and only works with some Android phones and Mirrorlink  after that date cars were classes as 2016 models and have an updated Bolero which works with iPad, Android and I think Mirrorlink. You could ask your Skoda dealer if it’s a 2015 or 2016 model. I have never been offered an update for my cars Bolero radio Joe
vag cars made from 1. july 2015. to 31. june 2016. are 2016 models. not from January to December.
so his car is 2016.
Hello, is there a newer software for Bolerom?
Hi there,
I have a skoda octavia (11/2015)
Is it possible to have android auto and apple carplay with this version?
Thanks a lot
  • 5 weeks later...
Hello, I got a Skoda Fabia III, 2016, do I need to upgrade my system?
Thanks.
2 hours ago, tschall said:
@pab567
Thanks.
Hello,
I need help with an update for our Fabia 3 (2017). Is there an update available for this entertainment system that I can perform by myself? It's got only USB ports.
Thanks in advance
