IHI users...
Hello all,
Just a quick note.
Those people who are running the IHI set-up in their octy's, do you know what your 1/4 mile time is?
if its anything like the times JBS' vRS put down then mid to low 14's due to massive traction problems off the line.
obviously Stuart J and his IHI 4x4 is going to be better off the line.
1/4 mile for the JBS Octavia when running the GT28RS was 13.1s.
not when i watched him at the pod it wasnt... i suppse he was having a bad day...
Sounds like it. 13.1 was timed by PVW the 2nd time the car was featured. Other figures on the day were 4.8 0-60 and 10.1 0-100.
eddy is that 13.1 with nos?
No, he's never run NOS on the GT28RS, he only ever used it on the standard turbo.
EDIT: When running Revo + 75shot of NOS on standard turbo the figures were as follows:
0-60 6.3s
0-100 12.99s
1/4 mile 14.45s
I thought there were figures of 400 bhp and a 100 shot of nos, 400bhp on standard turbo?
No, the first figures I posted were GT28RS with a claimed 440bhp WITHOUT NOS. 2nd figures in my edited post are for Revo + 75shot on standard turbo so power would have been around 300bhp.
I seem to remember the most power he got out of the standard turbo with nitrous was between 300 and 320bhp. I drove it with this spec and it was v.quick indeed. It was this spec the first time we went to Bruntingthorpe with PVW (where I ran my Nitroused Polo GTi - badly LOL).
The 13.1s 1/4 was also at Brunters, timed with PVW's V-Box with a GT28RS-JBS Turbo, running Custom Code Phase Three and definately NO NOS.
I am very eager to see what it will run now!!!
Remember that Bruntingthorpe is an air strip. When I was last there, there was a lot of grit on the runway and the quality of the strip isn't fantastic, so grip is nowhere near what you'd get at a drag strip such as Santa Pod.
Well we will never know as I dont do drag starts, with all the grip the 4x4 gives I have respect for the transmission (& my wallet), if the wheels dont slip, the paddle clutch wont so that leaves gearbox & drive shafts to take the strain, the next weakest link.
As a rule I wont floor the car until Im rolling & usually that means in second. I get more satisfaction out ofnailing it through the twisties where it just hangs on & goes :thumbup: :thumbup: .
Hmmmmm, interesting. Cheers for all your replies chaps! Something to consider in the very soon future i guess :D
  • Administrators
Remember that Bruntingthorpe is an air strip. When I was last there' date=' there was a lot of grit on the runway and the quality of the strip isn't fantastic, so grip is nowhere near what you'd get at a drag strip such as Santa Pod.[/quote']
He was also running the softest road legal compound Khumos going...which grip like hell, not quite as good as slicks, but not far off...there is a hell of a lot of grip at brunters with sticky tyres, my inters bite and they are good for 10k not 1k miles.
I thought he was running a 100 shot of nos, which makes 320 not alot...but then we know the k03s does not do much above 220 anyway :)
You're mixing up the dates Colin, but yeah...
Soft tyres on the GT28RS-JBS day...
100 Shot (which never actually gives a full 100bhp imho) and K03S on the time I went with him (there was grit and salt on the runway as it was winter and the runway was in use). He had Uniroyal Rainsports on then IIRC.
  • Administrators
Right, I'll get me coat... :)
i thought it dynoed at 440 without nitrous :confused: i remember someone posted the printout from a rr day a while ago in the gallery
theres a few leons up here which will we running fairly big power up hear in the next couple of weeks, robdon (which has a 180 engine) is getting an ATP GT2x which should see around 300 or BHP.
craigs(who again has the 180 engine) is getting a GTRS which will have around 350bhp(should be finished this week) and john's(is a cupra not sure is its a 210 or 225) which has an IHI and 368bhp.
only one i know of thats been on the 1/4mile out of those 3 is craig with his old set up (280bhp on a hybird KO4) did a 14.1 or there abouts with no traction at all cause it was so wet.
You're mixing up the dates Colin' date=' but yeah...
100 Shot (which never actually gives a full 100bhp imho) and K03S on the time I went with him (there was grit and salt on the runway as it was winter and the runway was in use). He had Uniroyal Rainsports on then IIRC.[/quote']
Josh,
I thought James was running a GT28/71r not the so called Disco potato.
:confused: as the 28rs only flows 350.
Josh' date='
:confused: as the 28rs only flows 350.[/quote']
I think you're right Des, not sure on the exact spec but I believe it's based on the gt2871, however in fairness to Josh JBS do call it the GT28RS-JBS or something along those lines.
Sorry Des, I'm not sure of the technicalities.
Eddy's right though... JBS have always called it an RS-JBS
Sorry Des' date=' I'm not sure of the technicalities.
Eddy's right though... JBS have always called it an RS-JBS[/quote']
Sheesh, I was getting worried there.....I thought james has managed to get silly BHP out of a 28rs. All OK now, checked my pulse and everything is back to normal. :thumbup:
if u wanted that IHI turbo fitted to an 225 engine, what would u need if u already had FMIC. New injectors?
Manifold, Up rated Fuel Pump, Induction Kit, Dump valve Boost controller Exhaust sysytem with large sports cat, Coolant pipes to & from the turbo, Boost pipe, exhaust temp sensor linked into cars electronics, miscelaneous gaskets etc, & a decent remap + a few bits Ive probably forgotten. Then theres a decent Clutch.
If you want aboove about 330 bhp you will need to consider Rods, Pistons & valves to guarantee a thrashable reliable car
To add its well worth it !!!!!!!!!!!!!
:D
Manifold' date=' Up rated Fuel Pump, Induction Kit, Dump valve Boost controller Exhaust sysytem with large sports cat, Coolant pipes to & from the turbo, Boost pipe, exhaust temp sensor linked into cars electronics, miscelaneous gaskets etc, & a decent remap + a few bits Ive probably forgotten. Then theres a decent Clutch.
To add its well worth it !!!!!!!!!!!!![/quote']
:D
